removing oil buildup in engine compartment
Old May 21, 2002 | 03:52 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
what is the best thing to do/us to remove excessive oil buildup in the engine compartment? there is currently NOTHING in my engine bay except: starter, ps pump, brake cylinder and lines, fuel lines and someting for the carb (donno exactly what it is ).. i would like to clean it up before i drop a new engine and tranny in the car.. its bad in some parts (almost an inch thick )
-mike (loomdog)
Old May 21, 2002 | 08:44 AM
Guido's Avatar
Car: 2000 Trans Am
For the really caked on stuff, use a putty scraper but try not to hit the metal. There *may* still be decent looking paint under there.
Then, go to a painting supply store and pick up a can of mineral spirits. That will clean off what is left really good.
Old May 21, 2002 | 08:54 AM
FatOne's Avatar
I did a 66 Chevy not to long ago. Lots of old grease and surface rust. First used some Simple Green. In spray bottle. You can use a putty knife or some type of wire brush. Then I applied a thin coat of aircraft and boat paint stripper. Can find this at almost any Hrdw store. Once again use knife or brush to scrape off. Wash off engine compartment. Sand and paint. Depends on how far you want to take it. If all the way to bare metal. This I would do. Also might try some oven cleaner!! "Remember safety with these chemicals"
Old May 21, 2002 | 09:18 PM
David M's Avatar
Car: '84 Z28
Engine: L69
I'll second that on the use of Simple Green. Thats good stuff!
Old May 21, 2002 | 09:26 PM
87'IROC5.0's Avatar
If you are worried about scratching the paint with a steel putty knife plastic ones are available in a number of different sizes. I got a set of three for less than two bucks at K-mart.
Old May 22, 2002 | 01:43 AM
loomdog32's Avatar
Car: 82 Camaro Z28
im not too worried about scratching the paint (some i already missing on the a arm (i think thats what its called - piece motor mounts to)).. i started using engine degeaser and stopped when i started raining/hailing (90 on sat and 60 on monday - cali does suck).. ill try the simple green/oven cleaner approach since ive heard so many ppl talk bout using it.. if i can get my friends dig cam to work ill post pics..
-mike (loomdog)
Vintageracer
Jan 10, 2020 05:33 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
