4th gen seats
Old May 24, 2002 | 09:01 AM
Brian'sIROC's Avatar
4th gen seats
I know that the 4th gen front seats bolt right into a 3rd gen, but what about the back seats? Do the seat backs and butt cushions bolt right in also?
Old May 24, 2002 | 10:02 AM
MNformula350's Avatar
Yep
Old May 25, 2002 | 08:52 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Anybody got pics of 4th gen front seats in a Thirdgen? Black leather? Anything?
Old May 25, 2002 | 09:29 AM
Saywhut's Avatar
Old May 27, 2002 | 12:55 AM
HrdRockA4305's Avatar
I posted a thread a while back with a step by step on how to do it. I think its actually 13mm bolts not 1/2' like I said before, but my toolset was a universal type. Workin on Black85transam's seats, we used a 13 mil.
To remove the back seats:
With a rachet and an extension, remove the single bolt that holds the bottom section of the rear seats. Then they just pop right out. Using a 13mm wrench, remove one bolt from each side of the rear seat upper panel from the hinge that it is attached to. The lift the seat back out. Reverse these steps to put the new seats in. Its that simple.
Old May 27, 2002 | 02:21 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
n/m pic doesn't work....
Old May 27, 2002 | 11:35 PM
Thanks for the help. i got the front and back seats out of a 95. They even match my door panels. Not bad for $160. They are 10 times more comfortable than the 3rd gen seats. And the whole swap only took 30 mins. with no cussing involved.
Old May 28, 2002 | 12:06 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
mine...93 Camaro buckets full set.
Old May 29, 2002 | 01:54 AM
jawzforlife1's Avatar
I want to get the 4th gen rd/darg gray seats like the post above.
My question: I dont have power seats but all the seats like that I have seen are power. How can i hook them up?
Old May 29, 2002 | 06:33 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Simple. There will be 2 wires coming out the bottom of the seat. Run the black wire to ground, and the orange to a constant 12 volt source.
When I installed my seats, I ran the orange one to the "BATT" outlet in the fuse box, and grounded the black one under the console.
If you get really lucky, there may be a plug in harness tucked under your carpet.
Old May 29, 2002 | 11:25 AM
sounds simple, thanks
Old May 29, 2002 | 08:36 PM
Quick6's Avatar
It is simple, I had mine in about 15 mins or so. Good Luck
Old May 29, 2002 | 08:57 PM
ThirdGenZ28 92's Avatar
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
99TA leather front seats....
Rears....
Old May 29, 2002 | 11:03 PM
Quick6's Avatar
98 Trans Am seats.
Old May 29, 2002 | 11:39 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
I think this is the rite pic.... I hope so!
Old May 29, 2002 | 11:43 PM
86FyrBrd's Avatar
Heres the rear
Old May 29, 2002 | 11:44 PM
86FyrBrd's Avatar
Last one, I miss my car, I want it back, its still in the shop!
Old Jun 1, 2002 | 02:04 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
what's getting done?
Old Jun 1, 2002 | 06:51 PM
86FyrBrd's Avatar
383 Stroker with LT1 Intake
Old Jun 1, 2002 | 08:57 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Well, in that case
Gonna make a big grin on your face when your get it back!
Old Jun 2, 2002 | 12:36 AM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
2001 Ebony Leather Seats from a T/A :hail:
:lala:
Old Jun 2, 2002 | 10:29 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
looking good wasem, what are you doing with the rest of the interior? btw - i saw your other post too
Old Jun 2, 2002 | 11:17 PM
Engine: 346ci LS1
Transmission: MN6
Not too sure what exactly to do next... I thought about doing some red embroidery on the seats, but I dunno. Then I thought about maybe some red neon's under the dash or something... Then thought about a 4th gen console but kinda nixed that idea seeing how I would have to chop up my current dash, that didn't thrill me too much. I'm always open to ideas!
btw - I returned your P/M from I dunno how long ago!
Old Jun 3, 2002 | 08:57 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
ifyour open to ideas, put a firebird dash and pod. You could go 4th gen or thirdgen, both would take custimizing, but the thirdgen dash in the camaro would be more unique. That would look cool anywayz.
Old Jun 3, 2002 | 09:56 PM
Engine: 346ci LS1
Transmission: MN6
Yeah I had thought about that as well, we shall see what my summer $$ brings! hehe
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
