heat not working??
Old May 27, 2002 | 11:14 PM
92 z28's Avatar
heat not working??
hey, i changed my thermostat in my 92 305 tbi, but my heat still plays games and decides to turn on and off as it pleases. lately it has been very bad, and not working to often. what can be causing this problem, and what can i do to diagnose the situation. please let me know. thanks
Dozer80464@aol.com
Old May 28, 2002 | 02:59 AM
IROCNParts's Avatar
Car: 1988 IROC-Z Convertible
Engine: 408 Stroker Turbo, TPIS Mini Ram
Transmission: Magnum t-56
Axle/Gears: Ford 9" 3.55
I had that problem when I had LOW water.. however.... it sounds like u probably filled it up... did u bleed the air out? and check the wiring..
Old May 28, 2002 | 09:52 AM
92 z28's Avatar
how do i bleed the air, or check the wiring?
Old May 28, 2002 | 10:06 AM
IROCNParts's Avatar
run the car with the rad cap off... and check the wiring to the heater control ... so you have to pull the console apart...
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
