My wing is very functional...
Old Aug 2, 2002 | 07:34 PM
  #51
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
yeah i have been out of the import scene now for about, well however long ago TF&TF came out, it was an ok racing movie, didn't like the cars, except for the supra and the charger... but i saw those tires in some magazine, i will go through them tonight and find which one it is....
why do i keep saying rims and not tires
Old Aug 2, 2002 | 08:04 PM
  #52
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I now have a sig pic
I now have a sig pic like rev limits but myne is SIGNIFIGENTLY ****yer.
Old Aug 3, 2002 | 02:29 AM
  #53
FLYNLOW92rs's Avatar
The tires are BF Goodrich Scorcher TA tires....
They come in 393 different color combinations......
Old Aug 5, 2002 | 04:39 PM
  #54
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Man up to that many now. Whew... When I got mine it was just red, blue, & yellow. Then they had custom colors available for order with a significant $ increase. They added purple, teal, green... not sure what other colors. I think it was 8-9 that you could mix and match. I remember seeing the ones that were paint splatters of color instead of stripes. I thought they had a solid colored tread too, but that was 2 years ago and prob a prototype. Who knows now.
Old Aug 5, 2002 | 07:22 PM
  #55
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Hey, I got my 86 LG4 to hit 5000rpm in 5th gear, that is about 157mph. Only had 3 mods on the car, here is a pic,
Stock exhaust, stock manifolds, and an MSD HEI Module, Edelbrock 1406 carb, 7101 Intake, and an Open Element Air Cleaner, so I guess I had 4 mods at the time.
Here is a vid of me taking out a built 72 Chevelle,
http://www.donpagevideo.com/video/Ze...s_Chevelle.mpg
I had the TPI setup on my car at that time,
Old Aug 5, 2002 | 08:19 PM
  #56
Cuno's Avatar
what tpi set-up did you use? a stock gm set-up or aftermarket?
Old Aug 5, 2002 | 10:03 PM
  #57
CrazyHawaiian's Avatar
Car: too many ...
Originally posted by ES87iroc
Yep, he sure can, but I bet my lunch that he has the stock speedometer. :sillylol: The 91/92 145 Z28 clusters are not exactly easy to come across, and they pull a premium when you -can- find one. With an aftermarket one, he would have to make up a new dash cluster panel, and I would wager that he would have pics up of it sience that would probably look pretty darn cool. I was thinking maybe he did the "well my speedometer is this far wrapped around so I -think- I am going X fast" thing, but those clusters have a needle stop on them from what I remember?
As far as the wing, yep, at least it is a RWD car.
Or maybe he was racing someone with a Speedometer that does go to 140mph and even though his was maxxed @ 110 the other driver was able to verify 140 mph. Not like people go out on the freeway and just go 140 for the heck of it. He was prolly racing someone dont you think? In fact I'm fairly certain he verified the speed racing his brothers 1985 mustang svo that I bought from him (his brother) that DOES have a 145 mph speedo, just not labeled past 85 (sneaky way to get around the laws in 85). And yes those cars can go over 140.
Old Aug 6, 2002 | 01:46 AM
  #58
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Awesome video Zeph.. I cant wait to see that car finished.
Old Aug 6, 2002 | 05:38 AM
  #59
Zepher's Avatar
It was a stock 87 that was converted to a 90-92 Speed Density.
I used the 87 TPI heads, installed a Crane Cams PowerMax 2050 Camshaft, and a 52mm Throttlebody.
here is a vid of the car 2 days after the TPI swap was finished and the exhaust put on, http://www.donpagevideo.com/video/ZepherWS6.mpg
Old Aug 6, 2002 | 05:50 AM
  #60
Zepher's Avatar
Thanks, but racing on the highway isn't very smart with traffic.
And all that smoke pouring out of my car was oil that was leaking from a bolt hole where the smog pump bracket was bolted and was burning up on the exhaust. I didn't put the bolt back in since I took the bracket off and had no idea that that was an oil passage. It only leaked at high RPMs. A friend of mine with a Monte Carlo SS told me about the bolt hole, so I put silicone on a bolt and put it into that hole. The fix was a little too late, my rod bearings had already started to go from lack of oil, and my piston rings were going bad from running way too rich for too long.
I hit a buck thirty on that run.
Old Aug 15, 2002 | 07:32 PM
  #61
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
man that might be the ugliest wing ive ever seen on a third gen what are you tryin to be euro......you really need to get rid of that thing thats an embarassment to camaro's everywhere...........
thanks haole boy
Old Aug 15, 2002 | 08:04 PM
  #62
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
dude.. prepare to get flamed. Your a newbie, your opinions on those "unique" camaro's will be considered invalid. No gives a sh;t about it anymore. Its not your car.. let it be.
Old Jan 15, 2003 | 09:20 PM
  #63
92Transam's Avatar
Car: 91 firebird now
Transmission: 5 speed
Originally posted by stuart69427
if you do a search, the fastest land record speed was set in a 92 firebird with the 85-89 style T/A Aero Wing
Just to get ya'll thinking that's the best stock spoiler for our cars. On a side note, they look great too.
You wouldn't be able to scan the pictures of the wing on a IROC would you? I would love to see it on a Camaro, but never have...
Yea that 92 bird did 200 MPH and they said the stock areo wing they had on there ( from a 90 car actualy ) was the best one they could have used for that kind of speed.
Old Jan 16, 2003 | 12:14 AM
  #64
bigals87z28's Avatar
Car: Check The Sig
im just saying this without lookin at what everyone else posted.... holy ricecakes batman.... i didnt know erector sets were popular with domestics.... im sorry... between this, and the clear lights thing... its just a matter of time before type R and fart tips start rollin in, if they arent here already... please take that *** awful wing of ur car and sell it to the guy with the 98hp civic... get an aero wing.. and wtf are u thinking doing 140 you dumb ***...
Old Jan 16, 2003 | 01:36 AM
  #65
NuclearPwrIroc's Avatar
Now i have some things im wondering about. What 110mph speed limiter exhists on any third gens? did the vss cars have an electronic govenor? My 89 has been pegged (i have the 145mph speedo) and that was when i bought the car and it was stock. what mods would anyone "need" to do to get there?
Old Jan 16, 2003 | 02:20 AM
  #66
Zepher's Avatar
my friends 91 305 Firebird had the 110mph limiter. I removed it for him since he went from a 2.73 geared rear to a 3.42 and the speedo would read 110 and the limiter would kick in and the actual speed of the car was 97 I think.
Oh, and the 92 Firebird with the 85-90 wing that I know of ran a best of 307mph.
Old Jan 16, 2003 | 02:23 AM
  #67
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i don't really care how functional that ugly *** wing is...doesn't matter to me if your doing 10 or 210, it's STILL fugly. If i find later that i need more stability than the excellent stability the stock spoilers already provide, i'll get the 5" spoiler copied off the 2nd gens. Never will my car see the day that crap is bolted to it....and redraif....your car is very red
Old Jan 16, 2003 | 03:27 AM
  #68
92Transam's Avatar
Yea your right I remember now I don't know why I said 200 mph it was an average of 300 mph from both the runs from one part of the salt flats to the the other but one of those runs was the 307 mph run but they average it all out. Here is the car.
Old Jan 16, 2003 | 06:35 AM
  #69
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Well once i get the 110 mph limiter on my car removed and find place to test it out, I hope to find out if my wing does anything for me...
how are you going to test it, if you have never driven you car above 110 without your wing.
Old Jan 16, 2003 | 10:13 AM
  #70
EvilCartman's Avatar
Car: '82 Z28
whoa this thread is back from the dead
Old Jan 16, 2003 | 11:01 AM
  #71
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
This thread is ancient
Old Jan 16, 2003 | 11:24 AM
  #72
redraif's Avatar
Mecham said this a very effective wing...Mecham holds the only SCCA Trans Am win that the Trans Am ever won!
Old Jan 16, 2003 | 11:27 AM
  #73
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
I like the exhaust on that trans am-----^
Old Jan 16, 2003 | 11:34 AM
  #74
LT1guy's Avatar
Car: 1987 Trans Am
That was my faborite thirdgen at the whole TA nats last year...he was in the winner's circle, so he couldn't compete, but it'll probably win its class this year. If ANYBODY has a Mecham wing for sale, or knows someone who does, please contact me!!!
Old Jan 16, 2003 | 11:40 AM
  #75
Zepher's Avatar
oh yeah. That Mecham wing is sweet. Time to change my body again.
Old Jan 16, 2003 | 04:46 PM
  #76
92Transam's Avatar
I like the wing and the side exit exhaust, anyone have a site on that car or some more info?
Old Jan 16, 2003 | 07:52 PM
  #77
Car: too many ...
I can understand why you would associate that style wing with Imports, seeing as alot of them run wings like that. But by labeling it as an 'Import Thing' and throwing it out the window, I think you are making a mistake. Just for a monent, forget about the whole Import/Domestic thing. Check out some real race cars that are designed to go fast around turns. Look at Lemans cars, the Corvette C5R, or any GT racing car. You'll find that alot of them run that style of adjustable wing. It is a proven design for track racing. Sure there might be other types of wings out there, but each design has a purpose, and has been proven for different types of racing. Compare the wing on that top speed salt flat racer to the wing on alot of fast drag racing cars. That low, close to the body design has been proven good for going straight. The 'GT' style wing (like the one in the original pic) is a wing that has been proven good when racing on a roadcourse. In reality, a street car will rarely reach speeds where these kind of things become functional. But it dosnt mean that it never happens. And if someone does want to run a wing like this to help them for those small moments of high speed racing (be it on the freeway, or on the straightaway of a track), I dont see anything wrong with it. Of course the question of ... better performance at high speed (downforce) vs worse performance at lower speeds (drag) is a question. Its up to how the wing is adjusted. Since this post was started, Revlimit removed the wing and sold it to some other 3rd gen owner here on the island. So the legacy lives on lol. I dont know exactly why he sold it, but I think its because it was only usefull freeway racing and freeway racing will get you in alot of trouble.
Sorry for the vent. I just see alot of good stuff passed up by domestic car owners just because import owners do it too. Just because they do something dosnt mean its dumb. Are racing seats dumb? How about lowering the weight of your car? I can guarantee you, everything Import guys have done has also been done on a domestic (to some extent). Its just the nature of racing. It might look dumb on their car if its slow, but by getting caught up in the 'Thats an Import thing, I'd never do that' you might be preventing yourself from getting the best performance possible.
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
codeysabatini
Sep 24, 2015 05:40 PM
Oenone
Aug 29, 2015 07:54 PM
LilHot
Aug 19, 2015 10:02 AM
