Leaking
Old Jun 22, 2002 | 06:09 PM
Rage13's Avatar
Car: 89 Firebird
Leaking
I've got a leak in my car, front passenger side... I know its not the heater, that was taken out long ago. And it only leaks when it rains, any spots our car's are known for leaking at?
Old Jun 23, 2002 | 10:22 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
How does all the weatherstripping look, do you have t tops?
Old Jun 23, 2002 | 11:09 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
does it still leak in the rain if it's sitting in the driveway? hose the hell out of it everywhere and have someone else sit in it and watch for water
Old Jun 24, 2002 | 12:33 AM
MG86TA's Avatar
I have an 86 Trans Am w/ T-Tops, which leak do you want me to explain?
Old Jun 24, 2002 | 03:15 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
For once Im the first person to reply that has the ANSWER!
I have the exact same problem. A pool develops on the floorboard under the dash on the passenger side that only shows up when it rains (or car wash)
Check in your engine bay...underneath the fan motor...tucked down behind the wheel well....you will find a load of debris collected over the years....this has rotted a hole in your firewall.
I pulled back the carpet in the passenger side footwell and I found the hole. Ive yet to figure out how to fix this problem. I may just JB weld a spot of sheet metal and udercoat it all.
If this isn't your problem I don't know what is.
Old Jun 24, 2002 | 03:56 PM
Buck268's Avatar
sounds just like what happens on my drivers side (91 RS coupe). I'll have to look into that debris idea...
Old Jun 24, 2002 | 05:25 PM
Rage13's Avatar
Car: 89 Firebird
That was it, thanks bill
Old Jun 25, 2002 | 04:00 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
This is exactly where mine went,it also did the same on the drivers side(and many other places for that matter).Imagine my surprise when I took the blower motor casing away and my hand went straight through the firewall!!!Nothing a mig welder won't fix
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
