Yet another window motor question...
Old Jul 17, 2002 | 12:59 AM
voltran's Avatar
I just got a motor that is attached to the regulator from e-bay. My question was is it easier or harder if I just swap the whole thing ?
And if anybody has done it before please give me some instructions. ( Yes, I read the article on the tech section already, I need the instructions for regulator )
Old Jul 17, 2002 | 10:46 PM
NCZ28's Avatar
I think it would be easier to replace the whole thing. Just drill out the rivets, slide it out the back, and bolt it back in the reverse order. It really isn't that hard. Sometimes the holes want to be a pain to line up, but just keep working with it and it will fit. Pay attention to the way you take it out. I think the tech article on this site is good, it helped me out a lot.
Old Jul 18, 2002 | 11:04 PM
MdFormula350's Avatar
i just drilled the rivets holding the motor, and swapped the motor, with my grandfather helping me it took about 1 hour and that includes the trip to the parts store.
Old Jul 19, 2002 | 12:44 AM
voltran's Avatar
Yea, but how did you drill the rivets out without taking the regulator off the window? . In the tech article it says "first take the regulator assembly off then drill the motor rivets out "
And also if you used bolts and nuts instead of rivets, what size were they ?
Old Jul 19, 2002 | 07:25 AM
Ok, what i did first was drill right through the door metal with a drill and drilled out the three rivets holding the motor on the regulator. I then had to drill the holes i made to get the old rivets out bigger so i could get the bolts through the door and then through the regulator and motor. After that i got the old motor to come out, and then put the new motor in place once lined up with the gear on the regulator.
When i bought the new motor it came with the nuts and bolts.
I used the tech atricle on here.
https://www.thirdgen.org/newdesign/t...rwindows.shtml
I did not feel like messing around with the regulator, so i just jamped the window with something to hold it up in the full position, while taking the old motor out and putting the new one in. It takes time and alot of patience. Do get mad if any thing happends, just take your time and follow the directions on that tech article.
Old Jul 19, 2002 | 10:40 AM
2vmodular's Avatar
follow the first link in my signature for some info on installing a window regulator.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
