how to drill a 2 1/16 inch hole in plastic?
Old Jul 31, 2002 | 10:25 AM
u r sofa king we tah did's Avatar
how can i drill a 2 1/16 inch hole in plastic? i need to make a hole for a gauge in something. or better, where can i get a bit that size.
Old Jul 31, 2002 | 10:27 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
You need a hole saw, NOT a drill "bit" , local harware store, tool store, etc. etc. I;d buy a 2" and ten file fit the 1/16, or if you are good with a drill get a 2 1/16" but be steady.........
Old Jul 31, 2002 | 10:54 AM
Matt427's Avatar
I'd use a sheet metal hole cutter. A hole saw will work, but it tends to leave rough, melted hole edges on plastic because of the friction heat generated.
Old Jul 31, 2002 | 01:15 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
I bet an almighty dremel would work too. Trace the circle out, then take a plastic cutting bit (I'm sure they have one for it), and cut that puppy out.
Old Jul 31, 2002 | 03:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Hole saw, little at a time so you dont heat the piece up a lot, high speed, tiny bit at a time, let it cool.
Old Jul 31, 2002 | 11:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i went to the hardware store and bought a 2 5/8" hole saw for my gauges and just went slow on drilling out plastic and it came out a little rough but the bezel on the gauge is slightly larger so you'll never see the rough stuff anyways. Hope this helps.
gta892000
Aug 11, 2019 11:16 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
katrav8
Sep 11, 2015 09:00 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
