need help removing the console lid
Old Aug 18, 2002 | 09:46 AM
Makai's Avatar
I removed the rear ashtray, and there is a spring attached to a clip and the arm that holds the door up. I can't get the ****ing thing off. Can someone give me dummy directions to remove this spring? I've tried grabbing it with pliers but either i'm weak, or it's just cause i'm a female. Oh, and ya might as well tell me how to put it back on. It looks pretty simple but removing it looked simple too!
I'm trying to replace the lid, mine is shot!
Thanx guys
Old Aug 18, 2002 | 10:54 AM
jawzforlife1's Avatar
Do you need to remove the lid (arm rest) or the ash tray?
Old Aug 18, 2002 | 03:01 PM
Makai's Avatar
Arm rest, and I figured it out. For anyone else who wants to know, slide that clip down (use pliers) while still attached to the spring, then undo the spring from the clip, then pull it up thru the top hole, and then remove the other half of the spring. Reverse steps to install.
Good luck
Old Mar 11, 2003 | 11:32 AM
xChRiSx's Avatar
where are you getting a replacement? I took off the spring to the curved metal so it wouldnt bend my hinges anymore, i straightened my hinge witha hammer and i just need a whole new lid because i cant make it look right with the cover coming off and the latch is broken. i wish i had a camera i'd post pics
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Fronzizzle
Sep 8, 2015 12:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
