Paint at home?
Old Aug 28, 2002 | 07:21 PM
SgtSkip's Avatar
Paint at home?
In the garage I mean. Good idea, bad idea, stupid idea??? You think of stuff like this when you're fiscally challanged.
Old Aug 28, 2002 | 10:12 PM
KsKid's Avatar
i had my hatch painted in a garage, the only thing that went badly with it was that a renegade hair decided to attack my car and now i have a little hair stuck in my paint, i'm sure i can take care of it... i just havnt gotten to it yet. just make sure nothing is around to get kicked up to land on your fresh paint
Old Aug 28, 2002 | 10:33 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Nothing wrong with that idea at all.....
http://www.deadbird.org/a/e10.jpg
http://www.deadbird.org/a/f01.jpg
http://www.deadbird.org/a/g05.jpg
Old Aug 28, 2002 | 11:35 PM
logikal6785's Avatar
oh ya i meant to tell you deadbird, i'm trailering my car to your garage so i can get new handles and paint =D
Old Aug 28, 2002 | 11:54 PM
deadbird's Avatar
Engine: TPI 305/ v6
:sillylol: I'll be here...just pick up a few cold ones for me on the way
Here's my friends truck I've been slowly (and I do mean slow :sillylol: ) working on as well in his garage..
Started as..
http://deadbird.web1000.com/72/a03.jpg
Slowly to..
http://deadbird.web1000.com/72/tr19.jpg
To (still unfinished) paint that looks like such..
http://deadbird.web1000.com/72/d02.jpg
Paint looks only as good as the prep. Even the best of the best paint jobs get crap in the paint and have to be color sanded and buffed.. just not quite as much as one's self doing it in their garage.
Old Aug 29, 2002 | 03:44 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
All you need to do is either have a 1 stall garage that has been cleaned compltely...probably even hosed out. All you need to do is get some box fans or something to draw air through the garage, and buy some home air filters that go in your furnace, and stick those in front of the fan... clean air coming in...clean inside garage.
If you have a large garage, I would suggest partitioning it off with plastic.
I know my dad has painted one of our cars in our garage, and we plan on repainting 2-3 more of our cars this way.
Like deadbird said... "it's only as good as the prep work" that is done ahead of the painting.
Old Aug 29, 2002 | 05:55 PM
SpeedJunkie's Avatar
Car: 88 IROC
See I have been wanting to paint my car for a very long time but I want to paint it a different color than maroon and maybe a PPG electron blue:hail: but what about the engine bay?
Deadbird did you do the engine bay too?
Old Aug 29, 2002 | 10:44 PM
deadbird's Avatar
Engine: TPI 305/ v6
Yes.. I painted the engine bay while my motor was out.. I did skimp doing it an used Plastikote spray bombs there at the time since I didn't have access to a paint gun or air compressor at the time. It didn't turn out bad but, I may redo it in the future.
Old Aug 29, 2002 | 10:47 PM
deadbird's Avatar
Engine: TPI 305/ v6
I also did this heap in the metal shop I used to work at and clean.. it wasn't (the shop that is)
Old Aug 29, 2002 | 10:49 PM
deadbird's Avatar
Engine: TPI 305/ v6
another..
deadbird's Avatar
Engine: TPI 305/ v6
one more..
Old Aug 29, 2002 | 10:59 PM
deadbird's Avatar
Engine: TPI 305/ v6
I also painted the suburban I used to have in the same shop.. these are the only 2 pics I ever took of it right before I sold it..
Old Aug 29, 2002 | 11:03 PM
deadbird's Avatar
Engine: TPI 305/ v6
billsfirebird (member name for search purposes) is also another member who has painted a car in his garage with excellent results.
Old Aug 30, 2002 | 12:35 AM
TTA155's Avatar
My dad and I painted at least 6 or 7 cars in the garage when I was living there. Put up lots of plastic, clean the floors (wash them down...maybe even leave a tiny bit of water on the floor) and make sure you have LOTS of lights at different heights. If you think you have enough lights, add more, then maybe you'll have enough. I'll scan some pics later and post them.
Old Aug 30, 2002 | 07:10 AM
SgtSkip's Avatar
I think you guys have about talked me into it. What kind of paint should I use if I decide to do it? Should I just get a book and go for it? How much should the paint be thined?
Old Aug 30, 2002 | 02:25 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
I dont have a garage at the moment. Would it be ok to prep (sand down, etch, primer) a car under a carport? Ill be having a friend paint in his shop but I want to do as much as I can myself. I can keep the car dry from the weather.
Old Aug 30, 2002 | 02:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I picked up the automotive paint & bodywork book from summitracing.com, it goes into the types of paint. Then I went and bought my Devilbiss Finishline II HVLP gravity-feed gun! http://www.eastwoodcompany.com wants $170, but i found it online for $125.
See me yapping about it here: https://www.thirdgen.org/techbb2/sho...hreadid=127245
The book is summitracing.com part # HPB-HP1082, see it here: http://store.summitracing.com/partdetail.asp?part=1784 You could probably get it from Barnes & Noble bn.com too.
And primer isn't waterproof, so Lock, make sure that car doesn't get wet under that carport!!! Read my "maaco" message for info on prep- don't sand down to bare metal unless absolutely necessary (fixing a dent or rust or poorly-adhered old paint) https://www.thirdgen.org/techbb2/sho...hreadid=100797
Old Aug 30, 2002 | 04:39 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i did it (not my camaro). it looked fine. the way i look at it is, if you get dirt in the paint, you can just wet sand it out.
Old Aug 30, 2002 | 08:31 PM
HamsterOnaMission's Avatar
even if your garage is clean, cover everything with plastic. seal all gaps of the car (ie door gaps, panel edges etc. soak with paint) then wipe the exteror of the car with clean rags and thinner to remove paint from the sealing process, and any overspray or contaminants, tac rag, and your ready to go..
BTW!!! IT is extremely important that you put water on the floor to trap dust etc. if you don't you'll see it in the finish (i didn't the first time and had to re-prep and paint a few days later to get rid of the dust.) Put enough water down to keep it wet while your in there, but not enough to pool it (splashing while painting is bad)
also when your done. leave don't go back or check on it till the paint has set up, as you risk drawing in dust hair or anything else.
I was told by the guy who heped me that the paint curing process creates static electricity, so any lint dust or hair gets sucked to the car. (ie no fuzzy sweaters in paint area)
if bugs or anything land on it and are standing let the paint set, and just cut them off at the surface with a sharp razor when the paint has cured.
Also beware. cats like wet paint.... lock the door
Hope this helped
Hotrodboba400
Dec 10, 2019 07:07 PM
Amillionoh7
Sep 11, 2015 11:36 AM
fasteddi
Sep 10, 2015 09:32 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
