Removing Bumper
Removing Bumper
im trying to lighten my car, i want to remove my front and rear bumpers, the metal part inside, will that have any effect on the frame, oviously if i got in an accedent id be ****ed, im going to have a 6 point roll cage and sfc's, will the frame be ok, or does it not effect it
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Bumper removal
Well you could do that but what you have to take into consideration is the fact that the bumpers contain impact absorbers so if you get rear ended or have a collision of any sort
kiss your car good bye coz when you get rear ended without the impact absorbers that can really screw up the frame and not to mention the body would possibly have to go to chop shop for some major repair work and that can led into thousands of dollars and I know first hand about being in some collison's .
trust me on this one you want to keep the impact absorbers or
other wise you 'll end up being forced to buy another car.
and think about how bad your engine could be badly damaged beyond repair!........think about thge future.
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
dude if you plan on driving your car on the street at any time...i wouldnt advise it...
i had to do it because with my custom front and rear end you could see the full bumber assembly through the mesh screening so i took them out...
my iroc is purely a show car and only gets driving to and from a show and an occasional cruise thats it...
its not that hard to do but make sure its what you want to do and that you know all the risks involved!!!
iroc2nv
iroc2nv
Car: 90 camaro
Engine: 355
Transmission: t10
Axle/Gears: 9" with 4.88's
i read some where that a guy removed his front bumper but at high speeds during one of his runs the nose peice sunk in due to lack of support but i think he runs low 10s high 9s i don't know if it's true so don't qote me on it
Engine: Classified
removing bumper
I've seen some cars with out the impact absorber and yes it is true that in some cases the nose will warp in extreme heat and with road wear can make your car look real "UGLY" but if you got a custom made nose that is made from stronger material it's gonna hold up better but against a slight impact noway jose!
Engine: Classified
NOW THATS SWEEEET!
NOW THATS A CAR THAT IS TOTALLY SWEET,AWESOME NOW THATS WHAT I LIKE TO SEE!
