door spoilers
Car: 1986 Pontiac Trans Am
Engine: LG4 305
door spoilers
how do you take the spoilers off the doors? on the inside there are two little "bumps" that seem to hold them on.. how do you take them off?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I'm guessing you mean the plastic ground effects that are on the doors? First, with the window down remove the inside door panel. Use a wide, flat screwdriver or other sort of tool. Then remove the plastic peice on the upper side of the door. Push it in towards the door then up, firmly but not violently. Once the panel is off, roll up the window and pull the protective translucent film up from the bottom of the door. Look for three small nuts. I think they were 10mm but I don't remember. Remove the nuts from those three bolts and the two 'bump's on the forward and aft sections of the door that you talked about. The plastic should pop right off.
Engine: LG4 305
i'm talking about the rocker panels.... they stick out the side of the door... is there anyway to take them off with out tearing apart my door?
removing the door panels takes me about 15-20 min for both... not hard, but the first time is a little un-nurving.
John
John
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
