t top leaks
Old Oct 11, 2002 | 08:56 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
t top leaks
my 84 t top leaks and i dont get why also my moldings that are on the door right by the mirror are all cracky where do i get them
Old Oct 13, 2002 | 03:49 PM
CaysE's Avatar
www.sunroofdoctor.com
or
www.gtrestoration.com
Good luck with it
Old Oct 14, 2002 | 10:17 AM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Transmission: 700 R4
If you're not hell-bent on doing it yourself, most glass places can clean it all up and replace whatever you need. Doesn't cost as much as you'd think (some places).
Old Oct 14, 2002 | 11:35 AM
jocww's Avatar
wanna tell me on of those places names
Old Oct 14, 2002 | 09:14 PM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
Well, i'm in ohio and you're not, so i can't really give you a name that would mean much to you. i just know that the place i'll be going for my windshield also does seals. (it's a glass place that mainly does windows in houses and offices, tint, and glass replacement) Theres a catalog that sells restoration stuff, i think it's called Eastwick, they might have the right stuff for you
Old Oct 16, 2002 | 10:38 AM
jocww's Avatar
u know if i sent them to you and then if you could flash the guy that services you and get it for free im willing to pay shipping both ways
Old Oct 17, 2002 | 11:47 AM
jocww's Avatar
i was just playin girlie
Old Oct 18, 2002 | 11:46 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
the seals from gm are 800. thats expensive for a bunch of foam.
Old Oct 18, 2002 | 11:53 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Are they gold plated too ??
You can get GM seal kits from www.tacreationsusa.com for $250 both sides (less s&h). I bought mine from them for $160 before GM hiked the price up on everyone.
Old Oct 19, 2002 | 07:34 PM
jocww's Avatar
dude thats like enuff to buy me a **** load of stuff 800 is way over priced even 160 is alot do u think i could justl ike tape stuff to it so it would stop
Old Oct 19, 2002 | 08:03 PM
@ZZKKER's Avatar
sorry i forgot to say that that price is for every weather seal except for the hatch and the hood seal. it is a good ideah to replace the door,window, and the thin strips on the door next to the window when you replace the t-tops seals, especilally if you have a dark colored car because they fry them selfs to death. it also helps prevent rustthrough on the doors, and a quieter interior. helps keep the bass in the car too
thanks
anthony
Old Oct 19, 2002 | 10:58 PM
jocww's Avatar
still a **** load of money if u ask me
Old Oct 19, 2002 | 11:57 PM
deadbird's Avatar
Engine: TPI 305/ v6
If you're too cheap to buy the seals then go get a roll of clear Scotch tape.
Old Oct 20, 2002 | 06:25 PM
@ZZKKER's Avatar
dont get me wrong, but yea it is $$$$$$, but you get what you pay for.
Old Oct 21, 2002 | 10:04 PM
Girlie85TA's Avatar
Car: 85 Trans Am
Engine: TPI 305
JOCWW
Funny funny stuff. Probably wouldn't work anyway...I went to school with the guy who does most of the work, but it's his mom who usually handles the money.
Old Oct 22, 2002 | 12:01 AM
jocww's Avatar
well that just sucks. will scotch tape really work
Old Oct 22, 2002 | 12:19 AM
deadbird's Avatar
Engine: TPI 305/ v6
It will for awhile until the weather & body/t-top movement gets to it and causes it to break/rip. Then you spend a few hours removing small bits of tape at a time that eventually ends up pissing you off until you just glue the damm things back in with a tube or two of black silicone and they still friggin leak on you. :finds happy place:.. or so I guess it can be somewhat like that....
Old Oct 23, 2002 | 10:47 PM
jocww's Avatar
hey u know where the mirrors are that plastic **** is all grey too and my friend pointed out that the inside seals are all cracked and the rear hatch seals are a little dry. how do you keep them soft. also how much for a intire kit
Old Oct 24, 2002 | 01:42 AM
spitz74's Avatar
You can adjust the fit of the T-Tops. The sleeve (in the A-Pillar/Windshield frame where the front outside corners of the tops meet the side windows) that the pin on the tops fits into to lock the tops down is adjustable (at least it is on my 92RS). When you take off the plastic molding that runs from the top of the windshield down the A-pillar to the front edge of the dash, you will see slots in the sleeve where it is mounted to the windshield frame. Loosen screws, move sleeve inward (towards seats), and voila, no leaks, no wind noise! (or at least less of both) If your seals are completely shot, this may not eliminate the problem, but it should help. Best of Luck.
Old Oct 25, 2002 | 12:05 AM
jocww's Avatar
thanks
Old Oct 7, 2009 | 08:31 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: t top leaks
any updates?
Old Nov 5, 2009 | 12:47 AM
jocww's Avatar
Re: t top leaks
can you say thread digger hahahaha. I havent driven my z in over 3 years.
xxx3man`
Sep 23, 2015 10:37 PM
mike_c
Aug 27, 2015 04:32 PM
TheExaminer
Aug 26, 2015 04:59 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
wayshegoes
Aug 17, 2015 12:00 PM
