need help badly- How do you swap a power window assy. into a crank door?
Old Oct 15, 2002 | 03:38 PM
rockfourone's Avatar
ok im in the middle of restoring my 1985 iroc and i need a new drivers side door due to all the dents. i got one for a steal but its a crank door and i have power windows. how do you swap the power window assembly from my original door into the new door that has a crank setup? i have no idea where to even begin. i know im going to have to cut some rivets, but i dont want to start butchering metal until i check with you guys. thanks
Old Oct 15, 2002 | 03:44 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I want to say you don't have to. I thought the door already had/has the holes for the rivets there. Maybe someone else konws for sure.
Old Oct 15, 2002 | 03:47 PM
no i mean i know you have to cut some rivets to get the crank assembly out and the motor assembly out of the bad door. i just want to know the steps and if it requires taking out the window or not.
Old Oct 15, 2002 | 04:41 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
why do u want electric windows. the motors are notorious for failure. i luv my cranks no need to swap
Old Oct 15, 2002 | 06:01 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Knock the centers out of the big rivits and then knock them sideways (off) with a chizel. The regulator falls out.
You should do this before you put it on the car so the window glass in/out will be easier. It won't scrape the A- pillar.
You should put the same style rivits back in. BIG gun needed for them however. Bolts can/will interfere with the glass, door panel, and usually loosen up in time.
Old Oct 15, 2002 | 09:55 PM
FLYNLOW92rs's Avatar
I remember did a picture how-to article......
Try a search to find the old posts.....
Old Oct 15, 2002 | 10:19 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
The tech article might help a little too. Its not about converting from manual to power I don't think, but you still might be able to find some helpful information
Power Windows Tech Article
Good luck
Old Oct 16, 2002 | 03:44 PM
ok thanks. yeah i dove into it deeper last night and found my worst nightmare.............a tensioner spring ::shivers:: i can tell already there are going to be some busted knuckles............
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
