Fitment problems on 4th gen console
Old Oct 15, 2002 | 07:25 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Hey guys, I picked up a 4th gen console for $60, its the one that has 4 cupholders so I'm guessing out of a 97+ Camaro/Firebird, it's 6 speed manual console, but I am still having problems getting the shift plate to fully latch onto the bottom part of the console. The shifter (inside) is in tbe way of the curve holding the cigarette lighter. Have any of you guys encountered this problem? Easy fix available? BTW I have an Auto.
Old Oct 15, 2002 | 10:34 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I had to notch my console where the shifter cable (I have an auto) goes through. This enabled me to sit the console down lower, flush with its surroundings.
Old Oct 16, 2002 | 10:42 PM
89V6FBIRD's Avatar
It's not the cable that's making it not fit, it's that semicircle part mounted on the right of the shifter, is there enough plastic under there to trim off without going through?
Old Oct 17, 2002 | 07:06 AM
scott's85T/A's Avatar
I had to move mine over a little bit to get it fit in there better,you can see the pics at nosaints site ,go HERE! then click on trans on the top left side then click on misc. on the right and you will see my install there.Hope that helps some.It would have fit without moving it but I think it looked like it was to far to the pass side.
Old Oct 17, 2002 | 11:42 PM
89V6FBIRD's Avatar
Oooh, dang missed by 1/2", that really sucks. I really don't want to move the shifter over. Is there an easier way?
Edit: If I don't have to get any extra brackets or bolts, moving the shifter looks easier enough. How long did it take you to do that?
Old Oct 18, 2002 | 06:14 AM
No you don't need to put the extra bracket in there and all you will need is a drill bit and about 10 min. easy to do.
Old Oct 20, 2002 | 11:07 PM
89V6FBIRD's Avatar
I got lucky, I didn't have to drill. The shifter just had to be loosened and pushed toward the back a bit, and the console pushed as far forward as possible. Now I have a great looking console and 4 cupholders!
Anyone want to buy a good condition 3rd gen auto Firebird Console with the holes for the window switches???
Old Oct 21, 2002 | 09:41 AM
Car: 1987 GTA
Transmission: 4L60e
I had to move mine over 1/2 an inch too.
Casey Meyers
Mar 2, 2016 10:46 AM
Omega
Oct 1, 2015 02:20 PM
sreZ28
Aug 14, 2015 07:48 PM
TheJoeY88
Aug 13, 2015 06:51 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
