Removing the speedo cable
Old Oct 25, 2002 | 02:12 PM
IROC-Z5.7TPI's Avatar
Car: 88 IROC-Z
Engine: 5.7 TPI
Transmission: 700 R-4
I need help getting my speedo cable out of the back of the speedo, its the onlything holding my cluster back. anyway i would appricitae any help someone would have taking it off, my car specs are in the sig, thanks a million
Joey
Old Oct 25, 2002 | 02:16 PM
CrazyHawaiian's Avatar
Car: too many ...
reach up from under the dash and pull the plug. it has a sliding locking thing, so pull it forward (towards the firewall) and it will come loose. then pull it out.
Old Oct 25, 2002 | 02:19 PM
Car: 88 IROC-Z
Engine: 5.7 TPI
I ve tried to reach up for it but theres so much shi%t in the way, am i missing something???
Car: 88 IROC-Z
Engine: 5.7 TPI
Should i take the sterring column out??
Old Oct 25, 2002 | 07:27 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
Tools needed, long flat tip screw driver and a flashlight.
Find where the cable is connected (should't be to hard) push on the locking tap with the screwdriver tip and pull on the cable at the same time.
Hope this help
Old Oct 25, 2002 | 07:49 PM
Car: too many ...
I know how u feel. It was a real PITA for me too. No need to drop the steering column (dont worry I wanted to do that too). Use the tip of a screwdriver, that a good idea.
Old Oct 25, 2002 | 09:04 PM
Car: 88 IROC-Z
Engine: 5.7 TPI
allright thanks for the help, after it stops raining im gonna head out there and and try it.
Old Oct 25, 2002 | 10:56 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
First time is a biatch till you learn how it works. Do the screwdriver tip that was mentioned. You have to push the tab in and just pull the cable off.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
TheTraut88
Sep 7, 2015 05:22 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
