Is there a way to get the button out of the shift knob????
Old Nov 11, 2002 | 04:47 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
Is there a way to get the button out of the shift ****????
Ok, I looked at some of the stuff people had painted on here, and I saw one I liked. It was the square shiftknob painted white, but the button was left black. I just took mine off, but I don't think I can get the button out... is there a way that I'm just not seeing right now, or am I gonna have to tape over the button and then paint it? I'm messing with painting some of my interior pieces since they're pretty ratty anway.... Thanks.
Old Nov 11, 2002 | 06:19 PM
CrazyHawaiian's Avatar
Car: too many ...
yah it comes out. pull the black cover off, twist the button 90 degrees and it comes out. dont loose the spring. there is a c-clip holding the handle on. use a flat head screwdriver to get it out. its located on the side facing the radio.
Old Nov 11, 2002 | 06:25 PM
Saywhut's Avatar
The black cover on the **** you depress comes off easily, just use a pic or screwdriver to pry it up. Then depress the **** itself, and the key will remain high. Twist the key 90 degrees, it comes out, then remove the **** & spring. Now you can remove the shifter handle itself, remove the C clip (staple looking thing) and it will pull right off.
Old Nov 11, 2002 | 06:30 PM
Hg's Avatar
Hg
Car: '87 Z
so i have to take the button off before i take the whole **** off? I just pulled the clip off and took the whole thing off....
Old Nov 11, 2002 | 06:56 PM
Car: too many ...
no it dosnt need to be in that order. all the button does is depress the white stick. you can use any universal auto shift ****. Revlimit gave me his cf shift ****. i like it!
Old Nov 11, 2002 | 07:02 PM
Hg's Avatar
Hg
Car: '87 Z
ok, so i actually pry up on the square button? it won't break off? i can see inside and see the little cross thing, but i can't twist the button enough to get it through the hole...
Old Nov 11, 2002 | 07:24 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Originally posted by CrazyHawaiian
... Revlimit gave me his cf shift ****. i like it!
Got any pics of it?
Old Nov 11, 2002 | 09:30 PM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
dont pry at the button!! underneath where the button goes in theres a clip in the shape of a C. just get a flathead srewdriver and pry the clip out and the butten just comes out.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
