Need some pics of camaro consoles
Old Nov 15, 2002 | 03:46 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Ok i just installed one in my bird and im hooking everything up and i find out i have no lighter/ash tray or anything to bolt my HVAC onto... what am i missing it would be great to get some pics of these places .. (hvac/radio pod w/ cover rmoved and ashtray/lighter) Thanks guys
Old Nov 15, 2002 | 05:58 PM
Fade00's Avatar
The camaro lighters were by the bezel.
Why use a Camaro console anyway? =\
Old Nov 15, 2002 | 06:26 PM
So ya mean the lighters werent on the console? And i got a camaro console cause i dont like the way the 85-92 console looks and couldnt find an 82-84 bird console. Plus the camaro consoles are just badass.
Old Nov 15, 2002 | 07:41 PM
Cuno's Avatar
the lighter for a camaro is up next to the gauge cluster. Upper right hand protruding squarish thing. It is the thing on the right side of the driver pod.
The HVAC bolts above the stereo. The ashtray goes below the stereo in the center console.
Old Nov 15, 2002 | 07:57 PM
Well luckily i dont smoke cause i wont have a lighter in my car...any pics of how the HVAC bolts on?? thers nothing to bonlt onto in there
Old Nov 16, 2002 | 11:45 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Here's how my SC looks...
Pete
Old Nov 16, 2002 | 04:10 PM
Do you have any pics of the radio , HVAC w/o the cover or preferably the bracket that the hvac connects to?
Thanks again
Old Nov 16, 2002 | 04:15 PM
Mathius's Avatar
I own this reference CD, if I could get you a bigger picture of this, would it help?
Here
Mathius
Old Nov 16, 2002 | 05:32 PM
Yeah if ya make it bigger i think that would do the trick thanks man.
Old Nov 17, 2002 | 01:01 PM
Thanks again
Afraid not, but the HVAC controls (mine are from a Firebird, BTW) are attached to a wide U-shaped sheetmetal bracket (something like this-> ||___|| ) using three 7 mm head screws; that bracket is, in turn, attached to the frame of the lower console using two more 7mm screws. The bracket itself is not flat, so it would be difficult, but not impossible, to make one to fit properly.
The ash tray used to sit just in front of the shifter, where you can now see two red pushbuttons.
Pete
Old Nov 17, 2002 | 01:09 PM
is this a piece i could just unbolt from a junkyard camaro and bolt into mine?or is it like welded or something?
Old Nov 17, 2002 | 01:20 PM
It's just bolted/screwed in place....a T-15 Torx to remove the faceplate, and a 7mm socket with a short extension to remove the bracket and HVAC controls from it...assuming they are still present.
Pete
Old Nov 17, 2002 | 03:22 PM
Thanks soo much man ill be goin to the junkyard this week
Old Nov 18, 2002 | 11:49 AM
badazz84camaro's Avatar
hey petes, how did you put the switches in the ashtray, i wanted to do that, but debating how to do it
1992 Trans Am
May 10, 2023 07:19 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Firebird sweden
Aug 16, 2015 05:02 PM
TheJoeY88
Aug 13, 2015 06:51 PM
sonu1975
Aug 11, 2015 08:38 AM
