Squeak/Squeal/Scrape noise
Old Nov 17, 2002 | 02:19 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I've had 5 thirdgens in my life (so far). Every single one of them made the subject line type of noise. It sounds like it comes from the drivers side dash. Has anyone else had this noise? It's pretty loud when going over bumps.
Anyone figure out what causes it?
Old Nov 17, 2002 | 10:43 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Well, a squeak and scrape are two very different things. My car creaks and squeaks, but I plan on fixing that with SFCs sometime.
Old Nov 17, 2002 | 10:51 PM
91RSGYEA's Avatar
i think u have some worn out shocks...........mine do the same thing but i'm not going to get new ones untill i drop the new motor in........i'd say get some new shocks and you will be set.
Old Nov 18, 2002 | 11:36 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I have new shocks and struts. I don't believe it to be suspension related. It sounds like it's actually IN the car.
It's a hard sound to explain. it almost sounds like wood with a heavy load on it being pushed on sealed concrete. (used to work on a receiving dock)
Old Nov 18, 2002 | 10:51 PM
Car: 1989 IROC-Z
Engine: 383 stroker
hmm... I'm trying to think but I really have no idea
Old Nov 19, 2002 | 08:33 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
have you checked for the infamous crack where the steering box bolts up, my SC had it, and I think my IROC might, despite the wonderbra
Old Nov 19, 2002 | 02:11 PM
MdFormula350's Avatar
i just have the typical creaks and squeaks!!
Old Nov 19, 2002 | 05:06 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
mine squeaks to but i think its mouse related
Old Nov 19, 2002 | 07:25 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I guess I'll have to check that. Thanks.
Old Nov 19, 2002 | 07:39 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
haha :lala:
Old Nov 19, 2002 | 09:24 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Just a suggestion that could be a pretty simple fix.... I had the same noise in my 87 TA... Sounded like a really loud creaking noise. Cant be produced by any other means other than driving... But one day I was putting my hood up and I heard it. So with the hood halfway up, i kind of jiggled it, and it would make the noise certain ways I would move it. My hood hinges have some play in them, and the shocks were bad. I replaced the shocks, and packed some white lithium grease in the hinges, and it went away. been about 4 months and I havent heard it. Just something simple to check out before you tear into anything big..
Justin
Old Nov 19, 2002 | 11:23 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
is it a creak/squeak that gets louder and faster as you drive? if so it may be your speedo cable. mine did that alot. so i ripped it out lubed it up and shoved it back in, havent heard it since.. another thing is it may be your windows, if they arent all the way up when you hit a bump it may kinda smack it.
Old Nov 20, 2002 | 02:49 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
the creaks and squeaks in my car come from the passenger side t-top
Old Nov 20, 2002 | 01:28 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
These cars sure do make a lot of noise.
I've replaced my hood shocks and packed the hinges with lithium grease earlier this year so I guess that's not it.
It doesn't matter how fast I'm going the noise is the same. It only happens over the worse bumps.
I don't have t-tops
This is driving me up the wall. I'm about to tear my whole dash out to find this gremlin. It makes my baby sound cheap.
Old Nov 20, 2002 | 10:35 PM
HamSpiced's Avatar
oooh... if its coming fromy uor dash i have a few easy suggestions.. the stock air ducts sometimes break and rattle.. i had to wrap all my air ducts in some material to dampen the sound and that helped alot. maybe that will work.. if its within the speedo cluster it may be your speedo cable. for that remove and clean it, use white lithium grease to put it back. dont listen to anyone who says brake caliper grease works cause it dont!
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Nighthawkf-117
Sep 24, 2015 02:47 PM
Randomtask2
Sep 7, 2015 05:06 PM
