Power antenna
Old Nov 17, 2002 | 05:11 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
Power antenna
would like to install a power antenna in my 89 formula. has 3 wires comming out of it, need to know what each wire is for
Old Nov 17, 2002 | 08:23 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
One is for ground,one for constant +12v,and the other for switched +12v that comes on when the radio is turned on.This will usually go to the remote output of an aftermarket head unit. If your ant has universal aftermarket color wires on it,then red is 12 constant,blk is ground,and blue goes to the remote from the stereo.Hope this helps ya.
Old Nov 18, 2002 | 08:01 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
When I did my power ant, there were 3 wires... they went to a relay under my dash on the passenger side, if you remove the lower trim piece that has the "PERFORMANCE SUSPENSION" decal on it, under there... just rand the pink wire to the radio, the rest of the wires were there. so here is how it works
1 PINK wire from the Radio to the relay
1 Black (GROUND wire to the relay)
1 Orange (power) wire to the relay
IF I REMEMBER RIGHT:
1 Ground wire from the relay to the antenna
1 Gray wire from the relay to the antenna.
1 GREEN wire from the relay to the antenna
to test it is simple, take the wires and hook it up to a 12v power.
DO NOT HOOK THE WIRES DIRECTLY UP TO YOUR RADIO... THERE NEEDS TO BE A RELAY OTHERWISE IT WILL GO UP AND NOT DOWN, OR VISE VERSE. and it might blow something in your radio, it was not designed for that kind of power.
hope that helps.
Old Nov 18, 2002 | 12:32 PM
RSpeed's Avatar
Is it an aftermarket or factory piece? The aftermarket will already have the relat circuit built in.
Old Nov 18, 2002 | 02:24 PM
MdFormula350's Avatar
well i hooked the switched part of the power antenna to my aftermarket cd player and it workes like it did with the stock headunit in it... power on on the headunit turns the antenna up..
Old Nov 19, 2002 | 04:58 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
with an aftermarket radio alpine 7893 whats the best way to hook up
Old Nov 20, 2002 | 08:15 AM
okfoz's Avatar
I doubt highly that the radio will be able to withstand the draw from the power of the antenna motor... You will need the relay and hook it in...
Here is how, sorry electonic guys, I know all my symbols are not pefect but its close enough for this purpose
John
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
