!!!Please help me, ignition switch hard??!!
Old Nov 19, 2002 | 05:31 PM
Z28Bama's Avatar
!!!Please help me, can't turn key??!!
I am leaving thursday for IL to visit on leave. Well, after I put my radio in today, I had the shifter back in low gear, and tried to turn the key to accesorie. Well, something broke i guess, becuase now I cant turn the key. I can put it in and remove it, but cant turn it at all!!! How hard is it to replace the key switch ??? Is that the problem? please I must finish this tomorrow, thanks
Z28Bama
Old Nov 19, 2002 | 06:27 PM
SpeedJunkie's Avatar
Car: 88 IROC
I replaced mine during the summer. Its pretty easy. Lets see the steering wheel needs to come off. Go to like an autozone and rent a steering wheel puller. Then theres gonna be screws underneath that hold on this white plastic thing. Take those out. In a Clymer manual it shows one screw that holds it in. Take it out and the ignition slides right out.
Old Nov 19, 2002 | 06:37 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
that happened to me a couple times if ya pull on the steering wheel (toward you) and try to turn the key it will ussually work just try pulling it in diff angles/directions toward you while trying to turn the key.
Old Nov 19, 2002 | 10:21 PM
88txiroc's Avatar
Check your ignition switch located on the side of the steering column. That went out on mine and I could not move the key to any position. The switch was only like 20.00 at checker. Good luck. T
Old Nov 19, 2002 | 10:29 PM
bob8748's Avatar
Dont remember when I took the camaro apart, but on my daughters truck I had to buy a tool to compress the plate down to remove/install the snap ring holding the plate on... price of tool was only 6 bucks though.
Old Nov 19, 2002 | 10:58 PM
Z28Bama's Avatar
Most unlucky guy on this planet!!!!
O my F-ing ***!!!! My key cyclinder went bad in my S10 so I couldnt drive to get more parts!!! WTF!!!! Well, I borrowed someones car ad got the parts and pullers, finished the S10, gotta wait until tomorrow to buy some different bolts for the T/A. Later
BamaZ28
Old Dec 16, 2002 | 12:07 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
howcome you coming up here to crappy IL for ?? youre not havign very good luck with switches lol,. ive got a switch in an 88 i have no key for and been trying all sorts of keys i have in my junked past vehicles keys collection, so far no good yet.
good luck
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
