?'s about POR-15 and floorpan
Old Nov 24, 2002 | 11:39 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I was painting my floorpan today and it looks pretty decent.
Should one coat be fine? I was able to use one of the small cans to do the entire pass side and most of the tranny tunnel.
I'll have some pics tomorrow, got too dark to see anything and the pics would have been bad.
Old Nov 25, 2002 | 02:32 PM
LT1guy's Avatar
Car: 1987 Trans Am
As long as you have good coverage, it should be fine.
Old Nov 25, 2002 | 02:53 PM
Zepher's Avatar
Cool, thanks.
I couldn't get some of the padding off of the floorpan, so I painted around it. The glue was so strong.
I just took some pics of it, here they are,
Old Nov 25, 2002 | 04:56 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
I did that to my firebird. My floor looked the about the same on the passenger, but it had holes on the drivers side.
I used Rust coat.
Its pretty much the same idea, I took a wire wheel on a grinder cleaned up the rust, and applied one thick coat of the paint, let it dry, then bought a 1Litre can of rustcheck, and applied a lay of that to the whole floor, then put the foam stuff back over top.
I was hoping that it would slow down the future rust from the inside of the car.
Old Nov 25, 2002 | 07:20 PM
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
Zepher where did you get por 15 from? and are you going to do the underside of the car? I just pulled up my carpet to. didnt like the what I found.
Old Nov 25, 2002 | 08:06 PM
Zepher's Avatar
My friend gave me two bottles of the POR-15. It's available online at por15.ciom or por-15.com
Old Nov 25, 2002 | 08:32 PM
2vmodular's Avatar
Even in "rust free" enviroments where road salt is not used in the winter, the floor in t-top equipped cars is often rusty especially towards the drivers side gas and brake pedal area.
Old Nov 25, 2002 | 11:10 PM
IROC_5796's Avatar
do u guys figure its worth it to replace the floor, i have no holes but its rusty looking, ure right about the t tops i have 4 f bodys, 2 hard top 2 t tops, i check all and I found more rust on the t top floors, and almost nothing on the hard tops
Old Nov 26, 2002 | 12:49 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
The trick to whether or not to replace the floorpans is the extent of the rust damage.. Is is just surface? With the carpet up poke at the rust with a metal tool (screwdriver) and test to see if it is hiding any damage that goes straight through the floor pan.. Lift up the car and look at the underneath of the floorboards..
IF the rust is just surface rust, get some POR 15 a wire brush and go to work.. you can get enough for the entire floor area for less than thirty bucks and it is good insurance.. Replacing the floor pan is simply adding work, don't borrow trouble. IF the rust penetrates all the way through, then that is decision time.. POR 15 sells kits that can repair rust penetrated areas like trunks and floor pans, which are a viable option for minor problems.. if their are some major problems, cover it all up until you have enough money to replace the floorpan with a replacement from classic industries or some other vendor...
Old Nov 26, 2002 | 09:30 AM
LT1guy's Avatar
Car: 1987 Trans Am
Holes are best filled by replacing the metal with a patch or a floorpan, but small stuff can be repaired with fiberglass matting and resin. Its strong, and can be undercoated over on the bottom so the repair isn't obvious. Its not the best way to do it, but it'll get the job done if you don't have a welder.
Old Nov 26, 2002 | 02:40 PM
IROC_5796's Avatar
i have a welder so thats not a problem or nothing, i only have a little hole on the drivers side about the size of the dime, so no big deal, what do u guys figure is the best for doing the underside of the car, i thought about undercoating but i want somthing thats going to stay on the metal and not be sticky, black is a prefered color.
Old Nov 26, 2002 | 02:56 PM
LT1guy's Avatar
Car: 1987 Trans Am
You can still undercoat it, but paint it afterwards...that will make it less tacky when working on the car, plus easier to clean.
Old Nov 26, 2002 | 03:08 PM
IROC_5796's Avatar
what would be a good thing to paint over the undercoating.
Old Nov 26, 2002 | 03:39 PM
LT1guy's Avatar
Car: 1987 Trans Am
Regular automotive paint would be best, like say a single stage urethane, but even good quality rattle cans (Duplicolor, Krylon, etc) will work fine.
3.8TransAM
Sep 17, 2015 02:16 PM
Belker
Apr 22, 2002 09:07 AM
Buck268
Aftermarket Product Review
Feb 13, 2002 05:09 PM
RSRagtop
Jan 24, 2002 06:54 AM
clemsparks
Mar 29, 2001 07:32 AM
