Hatch Shut
Old Dec 7, 2002 | 01:00 PM
AFast83z28's Avatar
Hatch Shut
My hatch does not shut all the way. If I put a new hatch lock (bottom piece) in to hold it down do you think that would fit it? I looked at mine and it is busted up bad.
Old Dec 7, 2002 | 01:03 PM
kinda_low's Avatar
Car: 89 Mustang
Engine: 5.0
Same problem here
Old Dec 8, 2002 | 04:44 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
More than likely the hatch pull-down plastic motor housing has broken where the 3 screws mount it to the metal frame. You need to replace this. I sell a specially reinforced one (p/n 103121). It is available on my web site under the "Hatch pull-down items" category.
Lon Salgren
Top-Down Solutions
TDS web site
Old Dec 13, 2002 | 10:27 AM
AFast83z28's Avatar
Hatch
I don't see it on there. How much is it? My little plastic pieces inside are broke. I don't have electric pull down no more, I don't believe. I would like it though
Old Dec 13, 2002 | 11:03 AM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
ok guys this ur problems, either ur hatch it self is off a bit, or your locks plastic support peice of the locking motor is busted, open up your back remove everything, take a look at ur hatch lock, if the motor is hanging, it means that it got dissconnectd from the main support of the car, if u want to close ur hatch tight, have someone push the lock in warms on the inside and have someone shut the hatch. it will catch and work.
cya
Old Dec 13, 2002 | 11:11 AM
lonsal's Avatar
Look at the bottom of the page under "Upcoming Products". Unfortunatly the 103121 Reinforced Motor Housing went out of stock yesterday 12/12. I have more housings on order and should be back in stock before the 12/23 date I listed.
Lon Salgren
Top-Down Solutions
TDS web site
Gunner242
Dec 25, 2015 04:49 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
formula00ra
Sep 28, 2015 11:50 AM
ironbmt
Sep 27, 2015 06:00 AM
