Camaro doors on a Firebird???
Old Dec 9, 2002 | 05:36 PM
1987fbd's Avatar
I thought I would throw this out there.
I have an 87 bird with crap doors.
I would like to put the doors off this parts car Camaro Ihave on it. The doors on the Camaro are eiher 84 or 91 doors. this car is a mix of both.
P.S. the car and its parts will be posted as well if anyone is interested or looking for anything.
Thanks all for the replies,
:hail:
By the way I forgot to add, neither car has ground effects.
Old Dec 10, 2002 | 09:18 AM
1987fbd's Avatar
NOBODY! KNOWS THE ANSWER???
Come on people I am losing faith in ya. I would like to do this on the weekend. As heavy as those doors are i dont want to take them off unless i know for sure.
Please help,
Old Dec 10, 2002 | 09:30 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I do belive that it will work for you. I remeber seeing a post here where someone put firebrid doors on a Camaro so....Yes it should work. Also try doing a search on this and see what you come up with first.
HTH
Keiran
Old Dec 10, 2002 | 10:46 AM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
I'm about 99% sure that the Firebirds/Camaros use the same doors. I also recommend doing a search on the boards...this HAD to have come up before somewhere.
Old Dec 10, 2002 | 11:36 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The doors are identical. Go ahead and use 'em. They came off the same assembly line together.all 82-92 door panels are interchangeable.
Old Dec 12, 2002 | 01:21 AM
1986tpiiroc's Avatar
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
Yes, they are interchangable, my friend had an 84 firebird that got hit on the passenger door and he used a door from a 90 Camaro. Was a perfect fit, just had to figure out how to get power to windows being that the firebird only had manuel ones and the Camaro door had power window/lock setup.
Old Dec 12, 2002 | 11:58 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
92 Firebird doors being fitted on my bro's 84 camaro...direct swap..
his 84 door panels on the 92 firebird door.....no mods.
Old Dec 12, 2002 | 12:00 PM
they are heavy, use some blocks or a jack and secure it while you put it on the car! Oh and get a friend or relative to help ya!
thats me getting a sore lower back!
Old Dec 12, 2002 | 12:01 PM
final product.
Old Dec 13, 2002 | 11:42 AM
1987fbd's Avatar
So Bill did you have to take the fenders off to fit the replacement doors on?
Thanks everyone for the input.
Old Dec 13, 2002 | 11:48 AM
We actually had the front fendors off because we replaced them. You can replace the doors with them on but it is MUCH easier to replace them and tweek them with the fendors off. You can just remove your inner fendor splash guard and gain access to the bolts too. Thats what I did with my firebird S/E It has camaro doors on it.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
BlackTopKing
Aug 19, 2015 12:13 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
