finished luxury molded door panel swap!
Old Dec 8, 2002 | 10:31 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
Heres a pic of before (top) and after (bottom). This project was a bear! But I think they look a lot more sporty than the regular style. I recoved the middle fabric section with the same black material as the headliner, kickpanels, and sailpanels.
You MUST get the arm rest bracket from the donor car. That was the pain really because I drilled out all those darn rivets broke about 5 bits. Then I just use screws and nuts to put the new one on. You gotta move the top piece as well.
Its not perfect but I think they look pretty good!
Old Dec 8, 2002 | 10:33 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Looks much cleaner. I like it. The original didn't quite seem to flow with the overall design of the car. Even though it was original. ^_^
Old Dec 8, 2002 | 10:36 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Very original. They look like the doors should open Lamborghini-style
Old Dec 9, 2002 | 07:57 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Correct me if I am wrong, but in order to actually do it RIGHT, you need to also change the door leaver... Because there is an extra bracket to screw in the plastic trim piece.
John
Old Dec 9, 2002 | 08:45 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
looks vary nice!
Old Dec 9, 2002 | 09:04 AM
MdFormula350's Avatar
sweet!!
Old Dec 9, 2002 | 10:48 AM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
What kind of door is that car out of? It looks incredible. Nice job!
Steve
Old Dec 9, 2002 | 10:51 AM
Jza's Avatar
Jza
:sillylol:
You mean what kind of car is that door out of?
<br>
<br>
Just ribbin'.
Old Dec 9, 2002 | 11:43 AM
Diggler86's Avatar
Car: 86 TA
thanks fellas!!
this door panel i *believe* was available as a "luxury" trim on TAs after 87, and may have come standard on the GTAs. not sure tho. i found mine in the boneyard, $24. hehe.
okfoz, you are correct, there is a screw under the firebird emblem on the new panel. you would need the correct door pull to use it BUT i found it unneccessary to hold the panel on. the fronts got a tab and the middle has a screw so it stays fine (i was happy about that).
Old Dec 9, 2002 | 12:36 PM
okfoz's Avatar
I found a set, and I was going to take them in BLACK no less, and I could have gotten them for $15 for the pair, but I him-hawed, and when I came back a few weeks later, some IDIOT brke them to pieces trying to get some small insignificant screw out of the door.
FOUND a second set at a boneyard up north, and the guy wanted $75 EACH, when I called him back he said $100 each, I told him to keep them...
John
Old Dec 9, 2002 | 01:46 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Looks FANTASTIC.
Old Dec 9, 2002 | 07:36 PM
Kandied91z's Avatar
looks nice; clean as well...........any close up pics??
i know i'd really like to do a newer door panel of such, i've been playing with quite a few different models; just wish i knew how to work with fiberglass as i would just make my own.
looks good though, much better than original!
Old Dec 9, 2002 | 09:36 PM
Diggler86's Avatar
Car: 86 TA
thanks kandied,
you can peel the vinyl off the cardboard mold. i actually did that then used trim adhesive to put it back on. it takes some pulling work but eventually works. you could do that and reupholster with new material. what i mean is, the molded board underneath would still be good for you to use instead of making your own with fiberglass. just an idea.
Old Dec 9, 2002 | 09:41 PM
91RSmaro's Avatar
looks good... you people make me jealous... you all have these nice clean cars... and then mine all stock... lol... but looking good
Old Dec 9, 2002 | 11:21 PM
Kandied91z's Avatar
everyone starts somewhere........i wish i had known about this site and similar ones like this when i first got my car. i'm willing to bet this site would have saved me 2-3,000 alone through trial and error of my own.
very helpful place, just remember there is always someone out there with a bigger, better, faster, all around nicer car. build it to your tastes and you'll be happy.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
