Replacing Fenders
Old Dec 11, 2002 | 05:25 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Replacing Fenders
How hard is it to replace a fender? Im going to be replacing my passenger side front fender soon and not sure how. It looks like i would brake the inner fender well plastic piece. Any help would be great.
Old Dec 11, 2002 | 06:36 PM
Drew's Avatar
Easy, but a pain in the ***.
Start by removing the inner fender liner.
Then the nose.
Remove the 10mm bolts across the top of the fender, then there's one 13mm bolt on the bottom of the fender in front of the doors. Remove it and the fender will fall off. Unless its the passengers side, in which case you'll need to pull the antenna too.
Old Dec 11, 2002 | 07:28 PM
Idlehands's Avatar
Car: 1985 Trans Am
Transmission: 5 Speed
no need to break the inner fender plastic, just remove the screws, its quite simple but take your time and i suggest applying some liquid wrench to the nose to fender bolts and letting them soak or they'll break for sure.
Old Dec 12, 2002 | 05:18 PM
OnFiRe705's Avatar
Sorry, i just got done replacing my passenger side fender, and it sucked. But it was on an 88 iroc, i wish i could tell you how firebird fenders came off.
OnFiRe705
Old Dec 13, 2002 | 08:21 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's also no need to remove the nose. Unbolt the fender from the nose, unbolt it from the rail support and from the rocker panel. Tape up the door and nose to protect it, and carefully work it out. You need to get the back out, then pull the fender back to get the studs out of the nose. Having somebody help you is a BIG plus, especially when dealing iwth the hood. After you've done it as many times as I have, you can get away with doing it yourself, but until then, plan on having help.
Old Dec 13, 2002 | 04:01 PM
OnFiRe705's Avatar
you are def right jim85iroc.....follow what he said. i didnt know if a firebird was different or not.
OnFiRe705
Old Dec 14, 2002 | 12:11 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
getting ready to pull off two RH side firebird fenders soon in next couple days this is good thread to see before doing this
is 10mm the only size am going to run into ?
thanks
Old Dec 14, 2002 | 12:57 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I'm going to be pulling off both of my fenders of my 91 Z28.....my plans are to install a set of the 1980-1981 Z28 fender vents (metal).....thought it would be alot easier to do alot of the work while the fenders are off the car......anyone have any tips on welding.... cutting....crimping.... anything....?? Do I have to remove the hood hinges to get the fenders off? It looks like the frame, the fender, the the hood hinge is all bolted together?? I wouldn't mind hearing everyone elses thoughts/opinions.....
customblackbird
Aug 15, 2021 10:16 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Amillionoh7
Aug 7, 2015 01:24 PM
