Fiberglass Cowl Scoop Trimming
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I just got my 2.5" Harwood cowl scoop. On the back there is a ridge that I would like to trim off. Now I know that this would hurt the rigidity of the piece, but how much? Would I be ok cutting it completely off? Trimming it almost completely off?
Brady
The part in red is the lip that I would like to see gone...
Brady
Car: 1989 IROC-Z
Go for it I would leave at least a 1/4 in of lip on the cowl for streath purposes. But you could just trim it all off if you would like. But it wont hurt anything just be very careful when cutting the peice
Car: 1989 IROC-Z
use a dremel if you have one. DO NOT USE ANY HAND TOOLS just so u dont run the risk of it crackin or breaking and make it your own so it stands out!!!
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
My Harwood has the same lip, but all the way around the hood. I'm going to trim it all down to 1/4" with my pneumatic cutoff wheel. It's a bit faster than the dremel because the wheel is a lot bigger. I've seen guys leave that lip and I really don't like the way it looks.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
