alarm ?
Old Dec 29, 2002 | 09:36 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
alarm ?
hey,
dont know if this goes here but i had a question about an alarm....i heard that they make a kind that is like a sensor for like a jeep or convertible and sensors go inside the car and if someone reaches inside when the top was down then the alarm goes off.....is there such a thing as this? thanks
Old Dec 30, 2002 | 05:58 AM
lane's Avatar
Yes, there is a sensor like that. I had it on my t-top, but disabled it because it gave a lot of false alarms. It was actually a dual zone sensor where you could set it to chirp or ring depending on how close there was movement in relation to the sensor. It has to be installed in the center of the vehicle for it to be effective, but like I said it gives false alarms.
Old Dec 30, 2002 | 10:17 AM
Jza's Avatar
Jza
Ask for "proximity sensors" or "microwave sensors".
Old Dec 30, 2002 | 11:19 AM
bubbakutz's Avatar
Engine: LG4
oh cuz i was actually thinking about getting one for my t-top camaro.....but does it give off a lot of false alarms? what would set it off?
Old Dec 30, 2002 | 02:14 PM
Jza's Avatar
Jza
I've not seen many problems with falses from the microwave sensors, but I know Viper alarms have "nuisance bypass circuitry" which cuts off a zone if it's been tripped repeatedly a certain number of times in a certain amount of time. Like it'll bypass your shock sensor if a thunderstorm keeps setting it off, or an intermittant door pin switch etc. Of couse that feature can be switched on or off...
Old Dec 30, 2002 | 02:22 PM
bubbakutz's Avatar
Engine: LG4
do any of these alarms have to have cars with power locks.....cuz my camaro doesnt have power locks
Old Dec 30, 2002 | 02:35 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Where?
BubbaKutz: I have a proximity sensor on my alarm for the same reason (t-tops). My problem is that when I took the car in to get the alarm installed, the interior was half ripped-out of it. When I picked-up the car, I found that they mounted the sensor between the seats on the hump where the console goes.
I'm hoping to put the car together this spring and I wanted to know where you guys with these motion sensors have the actual sensor mounted in the car (and does it work correctly there)? I was planning on just putting it inside the console.
1992Z28!
Nov 19, 2015 07:33 AM
Stauf
Aug 24, 2015 08:31 PM
camaro 22
Car Audio
19
Sep 25, 2001 02:53 AM
ADAM NEAL
Car Audio
Sep 19, 2001 11:24 PM
AmorgetRS
Car Audio
Sep 8, 2001 11:12 AM
