Who has converted their dash lights to LED's? Please Post Pics
Old Jan 7, 2003 | 10:05 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm going to probably do the conversion sometime before the winter but I want to see what color everyone has used and know how it turned out for you. I'm thinking of using blue LED's and getting the brightest I can because the stock dash lights just plain suck! Also I would definately like to see red because I just put red bulbs in my interior light sockets today.
Thanks.
Old Jan 7, 2003 | 10:23 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i have not done it yet, but i plan on doing it in my own custom way. i also am going to have custom leds in the tail lights,3rd brake light, and side marker lights, and possibly in the parking/turnsignal lights. but my setup will run in between 450 and 600 for the tail lights alone because of the amount of leds i plan on using.
just be sure that u use high disscharge wide dispertion patern leds, t get a unform light pattern, using any other led will result in a blotchy lighting effect.
thanks
anthony
Old Jan 7, 2003 | 10:41 PM
harry's91rs's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 LHO
I plan on doing thise to my car also. I have already ordered my LEDs and are waiting to get them. I would like to see some pics also. Also, How many LEDs did you guys use when you did the gauges?
Old Jan 7, 2003 | 10:58 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Here are some pics of mine.
Brian
Old Jan 7, 2003 | 11:59 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
that looks hella bright..
I like
Old Jan 8, 2003 | 04:20 AM
SuperchargedRS's Avatar
Car: Camaro of course
I think that when I do mine I'm going to use 97 Ford Explorer gauge pointers. They have a led behind them and are a fiber optic like effect to them, it's hard to explain...so just go look in a explorer and you'll know what I mean
Old Jan 8, 2003 | 09:52 AM
MdFormula350's Avatar
nice!! very bright indeed...
Old Jan 8, 2003 | 03:19 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
89blackGTA, how do you change the light scheme on the HVAC controls? where is the light for that and is it difficult? thx.
Old Jan 8, 2003 | 03:24 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
It is VERY easy! Three simple steps.
1. Take a pic of it
2. Put it on your computer
3. Photoshop it blue
I am working on changing the HVAC controls to blue. I was told that there is a light back there to change just like the dash but I havent taken it apart yet. I am going to get a HVAC unit out of a busted up TA and figure it out. I am just a little hesitant about ripping it out. Hopefully I will have it done this weekend.
Brian
Old Jan 8, 2003 | 10:24 PM
Car: 89 IROC-Z
Engine: 383
The pics look great! Are you the one that wrote the tech article that's on the board??
I would also still like to see red if anyone has them, but I think blue is probably the way to go.....just don't know how it would look with my red interior lights, but both aren't on at the same time very often so it wouldn't matter. Or I could change back to clear interior lights....no biggie.
Old Jan 9, 2003 | 11:49 AM
FRDH8R's Avatar
I've got the red LED's from superbrightleds.com and haven't installed them yet. Probably another week till i get around to it, but i'll post pics asap.
Old Jan 13, 2003 | 08:36 PM
Car: 89 IROC-Z
Engine: 383
FRDH8R....did you get to install your red ones yet? I'm waiting eagerly.
Old Jan 13, 2003 | 10:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
89blackGTA, there should be a 194 bulb that lights up the heater control panel. at least thats whats is in my camaro. Not sure if its 194 or something alse but its the same size as the 194 bulb.
Old Jan 14, 2003 | 11:40 AM
Diggler86's Avatar
Car: 86 TA
i looked at one at the boneyard and I think us TAs have 3 smaller bulbs, i think the number was like 73 or something.
im pulled the harness which has all 3 bulbs but Im working on switching them over to red LEDs. my only concern is that LEDs light are very unidirectional and may not shed the appropriate light.
Old Jan 15, 2003 | 03:10 PM
Diggler86's Avatar
Car: 86 TA
im dyslexic, its a 37 bulb, 3 of them..
the bad news is, if you replace them with an LED, it does not work since the light is unidirectional.
there is a clear plastic plate that distributes the light throughout the panel.
i am working on mounting LEDs instead of the plate, its alot of work and alot of LEDs but it should look cool. i will post pics when im done.
Old Jan 16, 2003 | 03:37 AM
FRDH8R's Avatar
Sorry, but I have yet to get 'em in. I've been busy workin on alot of other stuff to get her runnin' right, and have had little time for the small stuff. Should be happening soon tho, so I'll take a before and after for ya.
FRDH8R
Old Jan 17, 2003 | 10:16 PM
@ZZKKER's Avatar
there are different types of led's. there are wide dispertion patern ( like a normal light bulb) and narrow dispertion patern, (like a third brake light). then there are high, med. and low discharge LED's, which obviously, the high being the brightest.
you would want a wide dispertion, high discharge (or intensity) led in the color that you prefer, for the dash, or anywere replacing a normal bulb like a 194, 37, or 73 or any other incandesant bulb.
hope this sheds some "light" on things.
thanks
anthony
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
