how to fix this rustspot
Old Jan 13, 2003 | 07:46 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
my wheel wells are just totally rusted out. this is the only pic i have , the other side is worse, i can stick a screwdriver into my trunk from the wheel well. where can i get replacement wheel wells and how on earth do i put them in?
Thanks alot!
Old Jan 14, 2003 | 11:14 AM
MdFormula350's Avatar
i would maybe just weld in new sheet metal.. but first cover the rust with that por 15 stuff.. to stop it and then patch over it with new sheet metal..thats what i would do..
but i dont know anything about body work... just a guess.
Old Jan 14, 2003 | 12:11 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
if those are rotted through, you REALLY don't want to see what it looks like underneath your ground effects.
Old Jan 14, 2003 | 01:00 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Agreed.... take a look under your car and see how bad it is... man that salt really rapes metal If its only around that area i'd take a cut off tool to it and weld in some new sheet... hope your good with sheet metal fabrication :lala:
Old Jan 14, 2003 | 09:16 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
no dout! look at what I found under my back ground effect
that realy sucks
Old Jan 14, 2003 | 09:18 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
this will be good for a few hours bending up some sheet metal then welding.
Old Jan 14, 2003 | 09:19 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
well ive been under the car lots for various things and there is rust on the floor pans but nothing rotted through im going to wire wheel it down and then por 15 it. i never thought of under the ground fx, i guess ill be a bit upset when i take them off? ohh well, its all gettin painted anyways. so i cant get a replacement fender well? i guess thats ok. i just figured i wanted it to look like nothing was ever changed.
Old Jan 15, 2003 | 02:30 AM
SuperchargedRS's Avatar
Car: Camaro of course
I love my garage, I love my de-humidifier.
I almost bought a 68ish XKE that had a rusted rocker pannel, I found that one had to take a piece of sheet metal cut it to be the right shape, plasma cut the rusted areas off, heat n' beat the new piece untill it fit and lookedlike new (I dont like bondo) and than weld it, repaint and put a clear por-15 stripe on the bottom. Well that was my experience hope it helps.
Old Jan 15, 2003 | 03:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
If its only surface rust, you can just use a torch to sorta burn it off (NOT cut it off) can't you? i'm not 100% on this, so don't take my word for it, but a friend of mine is doing that with the trunk of his '67 Mustang, and from what i've heard, is going well (but i have not seen it myself)
Old Jan 17, 2003 | 12:14 AM
turismo's Avatar
Car: 1989 Trans Am GTA
my gta's wheel wells are worse. around the rim the rolled up metal is splitting apart. inside the wheel well I can stick a screw driver through pretty easily. it just gives way and just crunches.
I was thinking what it would look like if I took the side skirts off since even they're peeling off at the back top edge.
I've been under the car and there is no visible rust through the floor.
ah well.
Old Jan 18, 2003 | 02:20 AM
dans82bird's Avatar
Engine: 302
burn the rust off? hmmm ok the best way to do it is to cut that crap out and put in new metal...
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
