hatch motor and key lock Q
Old Jan 15, 2003 | 06:50 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
will hatch open and shut correctly if i remove hatch pull motor from it ?
andalso is key lock in the hatch same length as one in a trunk deck of other models of cars ?
thanks for anything
Old Jan 16, 2003 | 10:54 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
That would work for a short time. Unfortunately you are still relying on plastic components (the motor housing) which attach the latch portion to the frame with 3 screws. It isn't designed to withstand slamming the hatch closed, which is what you'll have to do once you defeat the pull-down motor. So, you are left with a couple of options. I see many in the junkyards that have had the latch portion bolted or welded to the frame part. This method will work and allow you to slam the hatch closed. Or you can rebuild your hatch pull-down unit to stronger than new using the parts I have available.
Good luck,
Lon
Old Jan 19, 2003 | 10:56 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
thanks for info, i appreciate it, so about how long or hard ot remove hatch motor assembly how many bolts or screws ?
thanks
Old Jan 19, 2003 | 11:52 PM
lonsal's Avatar
Download the instructions for the 101170 nylon guides from the Documentation section in the lower left portion of my web site and you'll see how easy it is.
Lon
Old Jan 20, 2003 | 12:15 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
http://www.top-downsolutions.com/images/203280front.jpg
thanks
Old Jan 20, 2003 | 12:21 AM
lonsal's Avatar
Yep. It slips into a slot on the plastic part called a "motor housing" that houses the gear nut. That style of motor has been discontinued by GM. They have replaced it with a new style which has an integral motor housing that screws to the motor with 2 screws. This is it:
Lon
Old Jan 20, 2003 | 01:14 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
interesting, hmm,,,
thanks!
BRoss99
Aug 10, 2025 05:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
