How do I remove the headlight knob?
Old Jan 17, 2003 | 01:00 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
How do I remove the headlight ****?
I want to remove my headlight **** to fix a wire behind the panel. How do I remove the ****, just yank on it real hard? Kinda scred to do that...wont it break?
Any of you guys removed it before? let me know how you did it...
thanks
Old Jan 17, 2003 | 01:10 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I want to say you have to go under the dash and get to the switch itself. Once there, there is a clip or a button that you push and it will release the **** and the rod.
Old Jan 17, 2003 | 01:25 PM
that doesnt sound right. I can remove the screws from the panel but I nned to get the **** off so that I can take the panel all the way off.
anyone got any ideas?
Old Jan 17, 2003 | 01:43 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
There is a small clip that holds the **** on. You will need a small flathead screw driver. Push the tab on the clip towards the rear of the car and pull on the ****, you will need to turn on your lights to get it off also.
Old Jan 17, 2003 | 01:59 PM
jawzforlife1's Avatar
On my car (91 camaro) there is a small pin wrapped in a spring that you push up with a screw driver, while holding the pin up, pull the **** out.
Old Jan 17, 2003 | 02:03 PM
Abubaca's Avatar
85 Sportscoupeto89RS is absolutely right.
It will take a good 2 seconds. Literally that easy!
Hey wishmaster......If you need help, I could come by.
hehehe......j/k.
Old Jan 17, 2003 | 02:08 PM
thanks guys
I'll give it a shot
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 6, 2015 11:40 PM
andy74
Sep 3, 2015 08:41 AM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
