What amp. & Gauge wire did you use?
Old Jan 29, 2003 | 02:01 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I putting in a Megashifter and want to know what amp&gauge wire did you guys with a megashifter use to wire up the reverse/nuetural and radio shack relays...it doesnt say in the instructions and I cant find it when I do a search?
Did you guys have to slide the shifter all the way back on the mounting bolts for it to fit right in the console with the plate on?...
thanks guys..
Old Jan 29, 2003 | 02:19 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe I used 18 or 20 gauge wire. It doesn't need to be as thick as the yellow or purple wires from the original P/N switch. Try to use heat shrink instead of electrical tape; tape will unfold when your console cooks in the hot sun.
Old Jan 31, 2003 | 10:13 AM
Jza's Avatar
Jza
It does say in the instructions. Look at the diagram and you'll see a little 18 or 10 next to the wires.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Jk_Under
Aug 17, 2015 03:08 PM
