how to repair speedo?
Car: Bonnievillie
Engine: 3.8L
Hey I remeber on one of my post there was someone who managed to fix there speedo without having to put a whole new one on it, how did you fix it?
what kinda glue did u use?
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
is your needle just pulled off or broke. would it read the speed if it still had the needle? ifyou are talking about the tripmeter, it takes some creative engineering to fix that. there are 2 tabs that hold the gears in place with a spring behind them, and over time the tabs break.
thanks
anthony
thanks
anthony
Car: Bonnievillie
Engine: 3.8L
the needle is fine, but the tip of the needle which connects to the dash it self got broken so I was thinking of glueing the tips together, the speedo still works
works better than before hahaha
but I just dont have a fraekin needle
just get anouther needle and change it. they pull off. u can glue it, but be carefull not to get glue on the shaft housing or it will be frozen.
thanks
anthony
thanks
anthony
rs_z28_vert
Sep 30, 2015 09:47 PM
