anyone replace thier airbag wheel with an aftermarket wheel?
Old Feb 22, 2003 | 12:21 PM
viperwsu's Avatar
Car: 91 Camaro RS
I am looking into replacing my stock airbag wheel with a Grant Evolution wheel. But they don't make an installation kit for any car that comes with an air bag. Has anyone ever replaced thier airbag with a grant wheel? How did you do it? Thanks!
Old Feb 22, 2003 | 01:16 PM
rxbxfx0220's Avatar
Hey, I put a grant on mine, but it didn't have an airbag. But what I thought you should know is that if you replace it with one that doesnt have the bag, you have to tell your insurance company, and i think it goes up. I'm not sure exactly how it works, but thats what I heard from a lot of people. just thought it might be good to ask around before you do anything. good luck!
Steve
Old Feb 22, 2003 | 01:46 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
tell the insurance comany??? fck no, why do they need to know. you wont have a case against gm if you get in a wreck though for the air bag not going off. there is a big law suit brewing from what i have been hearing from the insurance grape vine, because of older gm air bags not going off when they should.
you can do this pretty easy. the reason they dont make a kit is becasue you have a second clock spring for the airbag wires, which is in the way. to solve this, just unplug it and take it out. then the mounting kit should work. you may also have to remove your airbag light or just unplug the air bag module so you dont have that damn yellow light glaring at you.
good luck
thanks
anthony
Old Feb 22, 2003 | 03:59 PM
bravdawg's Avatar
how legal is it and is their anyway they can findout
Old Feb 22, 2003 | 04:18 PM
deadtrend1's Avatar
Im gonan save my stock one and when inspection comes around ill just toss it on without the air bag wired up.
Old Feb 22, 2003 | 04:21 PM
bravdawg's Avatar
this might sound stupid. when do u get ur car inspected. how often. what do they do. i am in ca
also, how do u remove the airbad
Old Feb 22, 2003 | 05:50 PM
viperwsu's Avatar
Car: 91 Camaro RS
I don't know about the inspections. I've had my car for 6 years, and I've never had it inspected. But then again, I also live in the buttcrack of nowhere.
To remove the airbag you have to, according to the manual, disconnect the pos battery cable, pull the SIR fuse, and disconnect the yellow SIR wire at the base of the steering column. It's not hard. Then there are 4 T30 (I think) torx bolts holding the airbag in, that you take out from the back of the wheel. Try to not keep your face over the module when you do that. Then just pull the module off, disconnect the wires, and you're done. I've done it without any trouble, but I've heard that these things are really touchy, and really powerful. I read an article about a guy who set it airbag side down, and set it off connecting the wires to a battery. The module went about 100 feet up, so be careful with it.
Old Feb 22, 2003 | 07:44 PM
25THRSS's Avatar
i think the airbag wheel actually looks better than the non air bag wheels. I wouldnt mess with it if i were you, besides it's there for a good reason.
Old Feb 22, 2003 | 07:52 PM
bravdawg's Avatar
if i did takeit off, i would put in something like the 3 point seat belt
Old Feb 22, 2003 | 10:46 PM
viperwsu's Avatar
Car: 91 Camaro RS
I tend to think that the airbag wheel looks good too, but the black cover over my airbag is slowly peeling off, and I can't get it to stay on, I've tried. Due to the price of replacement airbag modules, it would be cheaper to just replace the whole wheel. That, and I'm tired of spraining my thumbs to hit the horn
Old Feb 22, 2003 | 11:30 PM
25THRSS's Avatar
check ebay, i'm sure you could find a good deal on an airbag in good shape. I know what you mean about the horn though, sometimes it pisses me off, lol
Old Feb 22, 2003 | 11:38 PM
SuperchargedRS's Avatar
Car: Camaro of course
If you autoX dont get a airbag. I had a friend that had a blow out while racing (didnt 10-80 or anything, no damage at all infact) and the airbag whent off. Cost him like 600 in medical to fix his nose.
Old Feb 22, 2003 | 11:45 PM
25THRSS's Avatar
if you autox wouldnt you be wearing a helmet?
Old Feb 23, 2003 | 07:04 PM
......if you do it leagly.
Old Feb 23, 2003 | 07:19 PM
@ZZKKER's Avatar
i guess you would have to order the grant adapter plate that was for the air bag style shaft. they appear to be a little longer, therefore the addapter would be a little thicker.
hoe this helps
thanks
anthony
Old Feb 24, 2003 | 08:20 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
You can use the install kit offered for a pre-airbag car as the steering column is identical once the wheel is out of the way. I have a Grant Formula GT wheel and the only thing I had to do was put a washer under the column cover to prevent it from rubbing when turning.
Old Feb 26, 2003 | 02:29 PM
BOTTLEDZ28's Avatar
Transmission: A4
The hell with the horn button. I gave up on that along time ago. I just use the finger and the gas pedal for attention . The other thing I hate about my wheel is the size of it. Im always hitting my hips with my hand when the *** end is slidding all over the road sometimes it gets stuck there and my heart jumps out of my chest to help straighten it out. I gonna repalce my wheel with a 7" chrome chain wheel.
Old Feb 27, 2003 | 05:04 PM
Da91Bird's Avatar
I don't know what kind of car you have, so this may not apply to you. My 91 Firebird has the same problem with the airbag and the horn. The car is so low to the ground that idiots in trucks are always coming into my lane on top of me, so not having a horn really sucks. I just got on eBay and bought a wheel from and 89 Formula. It looks just like the airbag wheel, but it has no airbag and the horn will work. If you have a firebird you might try that. If you have a Camaro the same wheel might also work, but you'll have to live with it saying "Pontiac" in the center!!
Old Jun 1, 2003 | 01:52 AM
viperwsu's Avatar
Car: 91 Camaro RS
Originally posted by Da91Bird
I don't know what kind of car you have...
Riiiiight - forgot to put that part in my sig. I have a 91 Camaro
Frozer!!!
Jan 19, 2024 04:55 PM
Streetstuff
Sep 7, 2015 09:23 AM
kah992
Aug 19, 2015 02:55 PM
92purpz28
Aug 11, 2015 02:30 PM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
