Removing inner fender/splash guards
Old Mar 11, 2003 | 06:40 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
I have done a search on this and found nothing of relevance. I want to rustproof the Zee and to do the front wheel well I have to remove the black plastic spashguards. How can I do this and reuse the little clips?
Any help appreciated
Old Mar 11, 2003 | 07:13 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Pull the center section of the clip out first, then the rest will come out easily.
Old Mar 11, 2003 | 08:10 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Thanks Jim, how do you mean? Take a pair of pliers and pull the square head straight down? I guess my problem is that I don't know how the clip works- what does it clip into? Thanks
Old Mar 11, 2003 | 08:41 AM
transam305's Avatar
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
i think it clips into little holes but it has been forever and a day ago sence i took mine off of my old bird so i can't quite remember... too many rough nights ago... but i'll check it out tonight and get back with you tommarrow on it.
Old Mar 11, 2003 | 12:29 PM
Jim85IROC's Avatar
Just do what I said and you'll see how it works. The clip has a smaller center section, and a wider body. You pull the center section back, then the whole piece will come out of the hole.
That is unless somebody replaced them with the generic push-in style, in which case you just use pliers to pull them out.
Old Mar 11, 2003 | 01:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Shoot them with WD-40. Note that on either side of the head (the round piece) there's a flat spot/slot. I simply used a flat-bladded screw driver on either side and pried upward enough to get a needle nose on the stem. You can reuse with this method.
JamesC
Old Mar 11, 2003 | 03:25 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I take a pair of wire cutters, and pry with those, that way I can get under both sides at the same time, and the little wedges used for cutting slips under the head of the stem easily. Just pop them out, DON'T be cutting them off... It seems that about 50% of the time I pull the stem from the retainer, but you just push it back in, after its out of the car of course...
John
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
