Custom Door Panels
Old Mar 12, 2003 | 01:42 PM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Transmission: 4 spd Auto
Custom Door Panels
I searched previous posts and noticed that some of you have made your own door panels, using either hardboard or 1/8" plastic. My question is, how do you fasten it to the door? Do you still incorporate the standard plastic press-in fasteners on the edges? I am assuming not, as they fit into the cardboard door panels, in-between the layers, and so this would not work for a solid panel made of plastic. Please give me your thoughts, as I will be beginning fabrication this weekend. Also, does the gentleman who had the grey flame door panels have any installed pics? I would appreciate any other pics of custom jobs, just for ideas! Thanks in advance.
Old Mar 12, 2003 | 03:13 PM
383IROC's Avatar
My door panels do not weigh that much so I got away with using the armrests to fasten them to the door. It has been several months now and I have not had any problems with using this method.
If you are referring to my door panels here is the only picture I have of them.
Old Mar 12, 2003 | 07:22 PM
BTS88IROC's Avatar
I made my door panels out of plastic and still used the stock plastic pieces to hold the door panel on.
Old Mar 12, 2003 | 08:05 PM
Matt's Avatar
were do you guys get the plastic sheets?
Old Mar 12, 2003 | 11:21 PM
89FormulaRoth's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I'm glad you guys brought this subject up. I'm in the middle of making carbon fiber door panels at work and I'm not sure how to attach them either. If I make them flat, I thought I could use aircraft stainless washers/sheet metal screws. If I put some foam core board on the back, I could probably use the plastic "tree type" fasteners that hold the stock door panels on. You guys have any better ideas?
Old Mar 13, 2003 | 12:46 AM
BTS88IROC's Avatar
You should be able to get them from any upholstery shop, i got mine free but they retail around $60 a sheet or so, for a IIRC, about an 8ft x 4ft sheet.
Old Mar 13, 2003 | 01:12 PM
Fatal88's Avatar
Car: 1988 Z
I used MDF board you can get it at home depot. This material shapes and sands great. You can also use bondo to attach pieces and fill in spots. I used screws to hold my panle in. I traced the original shape of my panels to strat, then just went custom from there.
The flames are wood under the leather.
Old Mar 13, 2003 | 02:20 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
How do you attach the leather to the panel and make it keep the shape of the 'flames'?
Old Mar 13, 2003 | 04:00 PM
BTS88IROC's Avatar
Just use a good upholstery or interior adhesive and it will work fine. Instead of using wood you could just use foam to make the flames you want and then glue the material down onto it. Either way you just glue the material to whatever you are using. Just take your time and stretch the material to get out the wrinkles and press down good around the flames or whatever design you are doing.
Old Mar 13, 2003 | 05:01 PM
RSFreak's Avatar
Cool! I might try something like that.
Old Mar 13, 2003 | 05:38 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
wouldnt wood or something hard be better than foam. If someone were to throw an elbow into your door, bye bye flames.
Just wondering.
Brian
Old Mar 13, 2003 | 06:22 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
On Horsepower TV this past weekend, they visited Wyoming Tech, and they did custom door panels with flames. They used 1/8" plastic as a base, foam for the flames (they said cutting the flames at a 45* angle helps a lot), and more plastic for some pleats below the flames.
Old Mar 13, 2003 | 10:20 PM
BTS88IROC's Avatar
He's right on the 45* angle thing. That can make a world of difference. BTW, I just graduated from wyotech in december and that was my class where they taped that for horsepower tv.
Old Mar 14, 2003 | 12:27 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Just wondering.
Brian
Use closed cell foam. Closed cell foam is a bit more expensive, but keeps it's memory. It also glues better because the foam doesn't soak up all of the glue like regular foam does. While I was a custom audio installer, we did tons of door panels and amp racks with this method. We got our closed cell foam from the local interior shop, who also did the same style custom work.
Old Mar 15, 2003 | 10:12 PM
ERICK87Z28's Avatar
Car: 1988 IROC
Engine: 5.7 HO TPI
Great replies guys! Anyone else have any custom panels to share???
Old Dec 2, 2004 | 04:29 PM
camaro of solar's Avatar
humm very interesting...any places to get soem tweed for a nice cheep price? if so ill be redoing my seats and door panels
Old Dec 5, 2004 | 12:36 PM
sellmanb's Avatar
Car: '86 Berlinetta
You've got a PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
