4th gen console in my GTA. Help!
Old Mar 18, 2003 | 10:49 PM
KC10Chief's Avatar
I have the stock center console in my 88 GTA. It looks like crap. The sides are peeling away, it's warped looking, etc. Kind of like a lot of others I've seen. Anyways, if I order a 4th gen console, will it bolt right in or am I going to have to make some mods? If I order the console from Hawks, does it come with the lid and all that stuff I need? I can cut holes for the window switches. No big deal. What is under the lid on a 4th gen console? Matt
Old Mar 19, 2003 | 06:46 AM
scauffiel's Avatar
Here's a picture of what I found under my fourth gen console lid:
Old Mar 19, 2003 | 08:16 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
A 4th gen console will bolt right in. Under the lid is a storage area, just like the 3rd gens. Having never ordered from Hawks I don't know what comes with it. I got mine from an aquaintance. There really is no place to cut out for the window switches so I made a switch holder out of plexiglass and put that in place of the ashtray.
There are pictures on my web site.
Old Mar 19, 2003 | 10:19 AM
KC10Chief's Avatar
Is the cigarette lighter in the ashtray? I'd use the ashtray for my window switches, but I use the cigarette lighter t power my GPS. Matt
Old Mar 19, 2003 | 10:47 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
depeing on yr of the console, the cig lghter should be in its own little deal.
Old Mar 19, 2003 | 11:13 AM
cg91ta's Avatar
My 4th console has 2 cig lighters. One under the e-brake handle and one in the very front.
Old Mar 19, 2003 | 05:01 PM
firebird13's Avatar
hey cg91ta how hard was that?? im wanting to get 4 gen consol but i have power windows..what u just cut that out then fold under leather and just like screw it on?? tell me how u did it man thxs
adam
firebird13!
Old Mar 19, 2003 | 06:46 PM
cg91ta's Avatar
I took 1/8" plexiglass and gradually worked into shape to fit where the ashtray was in the console. Once it fit snug I found dead center on the plexi as it related to the hole I measured out and cut the hole for the power mirror switch. Once that was done I cut the holes for the window switches. It's a tight fit for all three but can be done. I used a Dremel and cutoff wheels (2 mounted together) to do the cutting. Once done and after I tweaked everything for fit, I spray painted the bottom of the plexi and let it dry. I then went and got a product from Ace hardware called "Plastic Weld" and placed the plexi in place of the ashtray lid in the console. I had to do a little more trimming to clear all the wiring and connectors. I used a couple c-clamps and glued it in. Some of the paint came off in the glue process, but you can hardly tell.
I had 3 peices of plexi that broke on me, or that I over shaped before I got it right. Go slow and easy!
Old Mar 19, 2003 | 06:55 PM
firebird13's Avatar
Souds cool..got any pics of it strait above it??
Old Mar 20, 2003 | 10:35 AM
Tonyrodz's Avatar
Transmission: auto
Here's a pic of my console in my T/A--it's the 93-95 style.
Attached Thumbnails 4th gen console in my GTA.  Help!-4th-gen-console-2
Old Mar 20, 2003 | 10:36 AM
Tonyrodz's Avatar
Transmission: auto
another
Attached Thumbnails 4th gen console in my GTA.  Help!-4th-gen-console-1
Old Mar 20, 2003 | 12:19 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
has anybody actually tried this with a convertible? I've always wanted to do it but i wasn't too sure on how to wire up the tonneau cover switch that sits in between the two power window switches. Anybody familiar with how the wiring on the cover realase works?
Old Mar 20, 2003 | 02:18 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Hey scauffeil, why dont you check this out.
https://www.thirdgen.org/techbb2/sho...hreadid=166721
What cg91ta has is exactly what I am wanting to do as soon as I find a console for a good price.
Brian
Old Mar 20, 2003 | 07:04 PM
cg91ta's Avatar
Here's a shot from above. Mind you it's filthy. nikh23, a switch is a switch. There's the wiring underneath, but if you don't have power mirrors I don't see why you couldn't put your switch where the power mirror switch is on mine.
HTH!
Old Mar 20, 2003 | 07:13 PM
nikh23's Avatar
i do have power windows as well as the tonneau cover release switch, if its nothign special then it shouldnt' be a problem. and also is there a reason why you also moved your rear view mirror button to the center console, was it just for convience or did you also do 4th gen door panels?
Old Mar 20, 2003 | 07:16 PM
cg91ta's Avatar
My mirror switch was always in my center console..
Old Mar 20, 2003 | 11:25 PM
Spdfrk1990's Avatar
very clean ta chris g
Old Mar 21, 2003 | 08:45 AM
Nasty_Bird_'90's Avatar
Where are you guys getting your consoles from? I can't find them anywhere for anything less that $125
Old Apr 1, 2003 | 09:59 PM
maverick544's Avatar
Stick consoel fit directly, but what about 4th gen auto consoles. HITHERE think they need minor alterations to fit right in auto 89 birds right. What kinda work you think?
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
Winchester1094
Interior Parts Wanted
Aug 19, 2015 05:01 PM
