Shift boot installation help.
Old Mar 23, 2003 | 11:29 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
This is really minor. But I was just curious. I just got a new leather shift boot from a friend of mine. For FREE!. Hard to beat isn't it? Anyway I was wondering if there is a way to remove the shifter plate console (it seems to be glued in) or do I have to remove the whole center console to do this swap? Any help would be appreciated. Thanks.
Old Mar 23, 2003 | 01:36 PM
BTS88IROC's Avatar
NM - I just saw you had a bird, so its different. Sorry
Old Mar 23, 2003 | 04:41 PM
87WS6's Avatar
Well I actually went and did it. I got the new boot installed and it looks great. I cleaned up my console and cleaned up all the damned cigarette butts that were lost underneath the ash tray. Cleaned the ash tray and repaired the cigarette lighter. I did manage to crack the very top of the shifter plate where it rests underneath the radio pod. This is no big deal as my plate looks like crap. Partially and mostly due to cigarette burns left in it from the last owner. But the shift boot looks greate and I know what I am going to have to do to replace my console and shifter plate when I get to it. But cleaning the thing inside and out has made a huge difference in it's appearance.
Old Apr 25, 2010 | 11:42 PM
gta90's Avatar
Car: 1990 GTA (T-Top)
Engine: 305 TPI (LB9) / 115k miles
Transmission: 4L60 (MD8 non-E)
Axle/Gears: 2.73 (GU2) 28 spline POSI (G80)
Re: Shift boot installation help.
How did you seperate the leather boot from the trim piece? On mine it seems to be glued as well. Should I disconnect the window/mirror connectors to get more slack to look under the trim in order to detach the shift boot from the trim?
Old Apr 27, 2010 | 11:05 PM
gta90's Avatar
sorry for being lazy and not investigating further. after removing all the wires there are 4 bolts attaching it underneath. piece of cake!
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Sep 7, 2015 01:37 PM
dhonda200
Aug 11, 2015 11:50 PM
Rustyweb7
Aug 9, 2015 03:05 AM
