Marker/Signal Light Question
Old Apr 16, 2003 | 04:04 PM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
I drive, almost exclusively, with my parking lights on...love the look of it, I guess...and last night was so bright out that I drove with them on only (just on a back road, nowhere populated, and very late at night). Anyways, I noticed when I put my signal on, the light doesn't go on/off/on to blink, it just gets brighter/dimmer/brighter...now I was wondering, is their any way to hard wire the signal light so it's always that bright...?? I'd love to find a way to brighten the intensity of the light emitted...
Old Apr 16, 2003 | 04:32 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I would not have a clue about hard wiring it to be brighter...but I have seen where, I think JC Whitney, Sells high intesity turn signal bulbs...they are supposed to be 2x as bright. That might be what you are looking for...they are a higher wattage bulb...I remember thumbing thru the cataloge and seeing them! I think with these bulbs, the dim is as bright as the normal bright blink... and the bright blink is even brighter...never have seen them in person though. check at your locak parts stores... see if they have higher wattage turn signal bulbs...
Old Apr 16, 2003 | 05:03 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
Just do the Daytime Running light mod like I did. Here is a pic with them on:
Attached Thumbnails Marker/Signal Light Question-06.jpg
Old Apr 16, 2003 | 05:05 PM
I bought a kit from a guy to get this to work but his site is gone.
Attached Thumbnails Marker/Signal Light Question-05.jpg
Old Apr 16, 2003 | 05:43 PM
Azure's Avatar
Turning them on is no problem, I just want them BRIGHT, like Corvette-esque intensity.
Old Apr 16, 2003 | 06:59 PM
Maybe you didn't understand, they are on the bright mode all the time with the DRL mode. Also only the two front ambers illuminate like on new vettes, and f-bodies, not all the parking lights like normal.
Old Apr 17, 2003 | 10:14 AM
redraif's Avatar
JC Whitney sells a kit for this as well. Not sure wht quality it is, but its probably a matter of a relay that ties into the wire that powers the bright filament
Vintageracer
Jan 10, 2020 05:33 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
