Gauges
Old Apr 21, 2003 | 02:44 PM
ZCAM875's Avatar
Gauges
I'm working on my girlfriend's 85 Formula. She has the gauge cluster that only goes to 85 mph. She woudl like to swap in a 145 mph cluster. My concern is weather it will work properly or not, because the oil and the gas gauge are reversed from the 85 cluster to the 145 cluster. Also, I'm not sure if the speedometer is cable or electronic. That is the end of the first question.
My other question is, about my 88 Formula. I'm sawpping a manual tranny in place of a auto tranny. I'm pretty sure the speedometer is electronic from the auto tranny. Than manual however, has a cable driven speedometer. How do I get the speedometer to work with the manual tranny.
Thanks,
Nick
Old Apr 22, 2003 | 02:44 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
you have been registered a long time for that to be your first post!
Old Apr 22, 2003 | 09:19 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Wow, almost 4 years to make your first post
C'mon Pontiac guys I know yall know the answer.
Old Apr 22, 2003 | 10:45 PM
Cuno's Avatar
It should work...I swapped out my gauge cluster(in Camaro) with the big gas gauge and 85mph speedo to the cluster with the tach and gauges. The cluster has the wiring on it so that everything should work correctly. I would imagine the speedo is cable driven.
Old Apr 23, 2003 | 12:11 AM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
wow really......i have the 85 mph and large gas in my 87 camaro...please pm me with more details and what u switched it to....thanks
Old Apr 23, 2003 | 08:05 AM
Car: 85 Camaro SC
Engine: V6
Ah, now the camaro's I do know. All you have to change is the oil pressure sending unit, and the temp sending unit. RIght now your SC has switch's. The gauge cluster is a direct bolt in. Also make sure to get a 80 PSI oil gauge.
Old Apr 23, 2003 | 09:23 AM
dd85T/A's Avatar
Car: 85 T/A
It is not a direct swap. The 85mph cluster is completly different then the 140mph cluster. I swapped mine in my 85 T/A. As you noticed the guage location is different. You will need to cut and splice the connections to allow the signal to go to the correct location. The pin-outs for the two connectors on the 85mph cluster is very different from the 140mph cluster. You will also need to add a buffer box for the electric speedometer. It does not matter what transmission you have but you will need an electric vss for the 5-speed. Its different from the auto. You will need to make sure you have the correct gears in the tail housing.
Old Apr 23, 2003 | 01:33 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you swap trannys and the gauge cluster, I have the Electronic VSS sender that bolts into the manual tranny.
It has the gear for a 3.27 rear end. If I change my dash, I may have the cluster and buffer box for sale as well.
Old Apr 23, 2003 | 02:38 PM
ZCAM875's Avatar
Where can I get a vss sender for a manual?
Old Apr 23, 2003 | 09:13 PM
bubbakutz's Avatar
Engine: LG4
damn i think swapping is outta my league
i dont think i can really do all that and not really mess things up
Old Apr 24, 2003 | 02:01 AM
Zepher's Avatar
From me. I have one that is for sale. $40 shipped and it's yours, as long as you live in the USA.
Old Apr 24, 2003 | 08:49 PM
Drakar's Avatar
Re: Gauges
Just had to point out there was no Formula in 85, but good to see your question got answered
And .... Welcome aboard
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
