Interior pix.
Old Apr 28, 2003 | 07:40 PM
ramair350's Avatar
Interior pix.
Does anyone want to show off their interior mods? I would kind of like to see just what everyone has done! Here is a shot of mine so far.
Old Apr 28, 2003 | 08:10 PM
camarokev400's Avatar
here is mine nothing special..... by the way that is an awesome spot for the cd changer i like that
Old Apr 28, 2003 | 08:23 PM
Matt's Avatar
that is a great spot, i asked about diong that about 1.5 years ago and everyone said it wouldnt work, then i sold my bird. How does it fit, how is it mounted?
Old Apr 28, 2003 | 09:41 PM
CaysE's Avatar
Personally, I'd put a PS2 there and keep the changer in the back somewhere. Still a nice looking install! How is it mounted?
Old Apr 28, 2003 | 10:22 PM
ramair350's Avatar
Well it took a little cutting with an air saw but it actually was pretty easy. Once I popped the map pocket off and cut the hole for the changer I realized that the vent tube was in the way. I blocked off the passenger vent and cut the tube off. I had to relocate the comp for the car over just a little bit then move the VATS control module which is located back there as well. After that I had plenty of room for the changer. I used two backstraps from some old CD players that I had installed and manufactured a mount that goes to the back of the changer and the firewall. That didn't provide enough support so I tapped another screw into the top of the changer and made another mount that wraped around one of the mounts to the passenger speaker. Once it was secure I made a black plexi trim ring that fit into the space that the map pocket came out of. The hardest thing that I have had to deal with over time was securing the trim ring to the changer. I ended up using epoxy and that has stuck so far. Thanks for the compliments!
Old Apr 29, 2003 | 12:29 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
ramair what did you do to your gauges in that pic? They look black. Is that a digital setup there?
Old Apr 29, 2003 | 12:41 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
hey camarokev can i see more pics of ur dash its that alumium or what it looks sick
Old Apr 29, 2003 | 01:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Mine is pretty basic,
Old Apr 29, 2003 | 03:32 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
almost a mod..all my money goes under the hood ..is removing the back seat an interior mod???
Oh yeah...and the GT steering wheel!
Old Apr 29, 2003 | 03:52 AM
Engine: 406
oops wrong camaro!!!!
Old Apr 29, 2003 | 05:56 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
stock as possible lol
Old Apr 29, 2003 | 05:57 AM
TekViper's Avatar
Engine: 3.1L v6
backseats, my little cdplayer mod for now. hid the cig adapter inside the center console and ran all the wires through there, and the cdplayer is velcro'd down. temporary until i find a headunit with cd.
Old Apr 29, 2003 | 07:43 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
That CD Changer is awesome
Old Apr 29, 2003 | 10:55 AM
No it is not aluminum just some silver spray paint... im too cheap to spend money on my interior, other than my gauges.
Old Apr 29, 2003 | 02:49 PM
ramair350's Avatar
That is an 1/8th" chunk of gray smoked plexi sandwiched in between my factory clear plastic and the guage trim bezel. It gives it the digital look without actually using digital guages. I prefer the analog guages myself. I have ingiglo guage inserts coming and debating whether to leave the smoked or go back to clear. The guage overlays are white when they are off so I am not sure yet what I want to do.
Old Apr 29, 2003 | 02:53 PM
ramair350's Avatar
Zepher- I like your three pod A-pillar pod. Where did you find it and how much di it run? If you don't mind me asking. And also does it just go over the factory A-pillar panel or does it replace it? Thanks!
Old Apr 29, 2003 | 05:04 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
Heres mine:
Old Apr 29, 2003 | 05:39 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
The only thing I changed in the interior so far:
Old Apr 29, 2003 | 07:13 PM
Engine: 406
Summit has them ...Look in the import section..LOL
Old Apr 29, 2003 | 08:05 PM
ramair350's Avatar
Nice! Thanks! I saw their two pod pillar but I didn't see the three pod one. That is why I asked.
Old Apr 29, 2003 | 09:05 PM
MdFormula350's Avatar
sweet pics! all different types of taste and all look great. :hail:
Old Apr 29, 2003 | 10:28 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Old Apr 29, 2003 | 11:45 PM
Zepher's Avatar
It was $53 from Jegs and bolts to the stock a-pillar.
Old Apr 30, 2003 | 12:28 AM
jocww's Avatar
john did u cut ur shifter down
camaro how did u spray ur dash did u take it out and mask everything or just leave it in and mask everything. how hard is it to take out the dash to paint
ramair350's Avatar
Great Thanks Zepher!
Old Apr 30, 2003 | 12:40 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
may of seen these already..
Old Apr 30, 2003 | 12:41 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
another
Old Apr 30, 2003 | 12:42 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
oh well its only bandwith..
Old Apr 30, 2003 | 12:49 AM
jocww's Avatar
wowsers thats alot of guages how much did tehy all cost
Old Apr 30, 2003 | 01:14 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Too much, it was all part of the big LT1 and drivetrain redo.. just one snowflake of the bigger snowball
around 500 or so..
Old Apr 30, 2003 | 04:54 AM
Engine: 406
CustomX..what did you do about the space left between the window and the dash pad in the middle?
Old Apr 30, 2003 | 08:59 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
Hey Julian (sp) was it hard to install that Grant safe/theft device for the steering wheel? becuz im lookin to gettin one and if i put in an 8 point roll bar it will help gettin in and out of the car
Old Apr 30, 2003 | 09:40 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Fibreglass and bondo to the rescue!
Old Apr 30, 2003 | 11:19 AM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Here's mine.
PM
Old Apr 30, 2003 | 11:57 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
johnsjj2 your shift lite is exactly where I wanna put mine, you are the first one I have seen do it...do you like? was it hard to run the wires back behind it?
Old Apr 30, 2003 | 12:29 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
It wa easy to install and has been in for 6 years with no trouble at all.. Makes changing the steering wheel really easy
Old Apr 30, 2003 | 06:27 PM
johnsjj2's Avatar
Car: 1991 Z-28
fast86z28,
No. The wires were easy. I did have to extend them a little. The hard part is getting it to stay there. I tried hot glue b/c thats all I had. i am going to try soem epoxy stuff and see how that does. I do really like it there.
RyanJB
May 7, 2016 06:23 PM
1MeanZ
Dec 18, 2015 05:39 AM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
