I mean are they good in tying the frame together I am planning a 300 hp build up do I even need em??
SFC's should have been the very first thing you did to your car.
IMO, get the Alstons, as they are by far the best. Do a search for Alston's, and you will find some pics that I posted of mine. Made a day and night difference in my car.
In my opinion if you just want to quiet the cars natural noises then yes.
They are fairly cheap. If you plan on making alot of horsepower in your car you need the extra rigidity for the frame.
I think they are kind of a pain in the aZZ to install. But worth it. I plan on getting a set very soon.
Lets see, if you have to ask if SFC's are worth it?? The answer is your case would be NO. Reason if you want a tighter & more rigid
car YES. Also 300Hp is not that much to worry about twisting the body.
do that without subframe connectors
Quote:
The picture proves nothing, you can do that without subframe connectors. Yes they are worth it, even in a v6 car.Originally posted by TheWraith
i think in that pic, the person said they could open and close the door fine if i am not mistaken that was said a while back or maybe it was another pic like that; i dont think i can do that yet.
spohn sfc's going in some time soon and then i may get the alstons also.
okfoz
close
- Join DateMar 2001
- LocationDoghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 Formula T-Top, 87 Formula HT
- Engine5.1L TPI, 5.0L TPI
- Transmission700R4, M5
- Axle/GearsSag 3.73, B&W 3.45
- Liked:197 Times in 142 Posts
Quote:
Your are right, you could take the same picture without SFC's, BUT after you remove the jack stand you would have some damage under your car...Originally posted by 82camaro
the SFC's give you some more optiosn for jacking up the car.
When I started to put any kind of power in my T-top car the FIRST thing I did was SFC's, and YES it was worth it. I got SSM's and am reasonably happy with them, unfortunately they came unpainted, so I had them powdercoated Black...
edit: Noticing in your sig that you have T-tops, I would almost definately suggest getting SFC's...
John
JamesC
close
Absolutely worth the time and expense. In my estimation, SFC's are not a mod but a necessity. Consider Global West's version.
JamesC
JamesC
Can someone take a picture of where they are, exactly. so I could check if our 87 has them.. perhaps one of the other owners did it
that would rock if they did
JamesC
close
Here's one.
JamesC
JamesC
http://homepage.mac.com/glenyappa/PhotoAlbum7.html
try this link it will show you everything about sfc
and YES they are a must for 3rd gens
what type are betta....the MAC/alston type or the spohn\ global west type
i have the ssm ones on my car
i dont think it matters what type you get as long as they are weld on !
If you do a search on the suspension board you will find many subjects on this.
But to answer your question I think they are an absolute necessity. I've seen plenty of cars (v-6's included) that have cracked at the top of the a-pillar, subframes would help to prevent this.
Also in reference to the picture above, I don't think I've ever had a f-body that could do that with out sfc's.
okfoz
close
- Join DateMar 2001
did most of you weld just the ends of the SFC's or did you go the whole length?
John
John
JamesC
close
Stitched them in every foot or so.
JamesC
JamesC
what brand?Originally posted by TheWraith
okfoz
close
- Join DateMar 2001
I do that with my SSM's.. not sure what brand that is. I know its nice cause it gives me alot of jacking points IF I were to need it.
John
John
Ohh.... I totaly forgot about SFC's when I was calculating my restoration price... argh, More money down the drain.
Yes, you want them, it wont kill your car or anything if you dont, but just for an overall nice ride they are a necassity(sp?)
BTW, thanks for reminding me.
That is looking to be my next thing to buy for my car. My car has t-tops and I am very familliar with the noises that everyone speaks of. I was looking to buy the TDS (Top Down Solutions) ones. As far as I read any SFC is better then done? Or should I spend my money for another company?
Yes....got my Hotchkis ones in today and I can't believe the difference. This is definitely without a doubt a must for these cars.
Wishmaster's87IROC
close
- Join DateFeb 2000
- LocationWinston salem, NC
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Car1987 1SICIROC.....1999 TransAm
- Engine385 HSR.....LS1
- Transmission700R4 with Midwest 3400 2.4str...M6
- Axle/GearsSLP Zexel Posi unit 3.42's...3.73's
- Liked:0 Times in 0 Posts
Quote:
You got anymore pics of the Hotchkis installed? Yours is the first to be posted anywhere. Originally posted by Trans Am#5
post some more..
thanks
I don't have any full length shots, but I'll give you what I've got.
Another...I don't have a pic of them before they were installed unfortunately. I can't believe the difference though. They fit perfectly. I got them today and installed them right away. Actually, I took it to a local place where a guy named John worked on it who is a fantastic welder. For anyone needing welding in the Chicago area....hes the guy.
did he pull up your carpeting and all that such on the interior? Somewhere I read that you have to do that when you weld them. Or is that just like a good measure thing when in reality you really don't have to...?
I'd say you need to lift up the carpet when welding them, why chance getting your carpet caught on fire. You could probably get away with not pulling up the carpet, but I'm sure you could get them welded faster if you don't have to worry about catching your carpet on fire. Why risk it??
Wishmaster's87IROC
close
- Join DateFeb 2000
I got the same SFC's.
I just havent had them installed yet. I wanted to see how you had yours done. werent you suppose to weld along the rocker panel too? It looks like your drivers side is not all the way up against it..
Man! I want get mine installed.
The guy that did mine asked me what I wanted done. He said he usually throws water on the carpet or can pull it up. Since I don't care about the carpet at all(getting replaced next spring), the water was fine for me. He also pulled the lower part of the passenger side wheel well to make sure the weld went well. He even commented on the fit being excellent from the Hotchkis SFCs. No it isn't touching up there. I got these for a steal and after installing them would have paid full retail for the difference.
Trans Am#5
What type of headers and exhaust are you running? Were there any clearance issues with the exhaust at all?
Thanks, Tony
Thanks, Tony
okfoz
close
- Join DateMar 2001
I FORGOT HE HEADER ISSUE!!!
When I did my SFC's I also was installing SLP headers & Cat-Back (a different topic) BUT I did have a bit of a problem on the passenger side with the SFC. The header would tap the SFC when I would start the engine, (ok it was more of a light BANG!) To fix it, I heated up the header pipeand I moved it about an inch to make for clearance.
On a side note I WOULD recommend the SLP Headers.
John
John
Okfoz - are you referring to the Sophn subframes that you had a clearance problem with?
okfoz
close
- Join DateMar 2001
no, ssm
John
John
Quote:
Originally posted by 85TPI400
Trans Am#5
Thanks, Tony
Since I have an Lt1, I have Hooker 3rd gen headers with A.I.R. Also, a Catco convertor with Flowmaster American Thunder 3" exhaust. The same shop, but different guy, made a custom Y-pipe for me because when I bought the headers(used), I didn't get one. I was there when he put that side on and I don't remember any issues with him having to bend anything out of the way for the SFC clearance. Overall, it is tight but does fit well. I would imagine this wouldn't be true for everyone since every exhaust setup, even duplicated ones, are always a little different.Originally posted by 85TPI400
Trans Am#5
Thanks, Tony
okfoz
close
- Join DateMar 2001
Trans Am#5,
Did you use standard 350 headers, or LT1 headers???
I have considered upgrading my LG4-TPI to an LT1 BUT I really do not want to buy new headers...
John
John
Quote:
Originally posted by okfoz
Trans Am#5,
John
Third gen headers are the only ones that will work with an Lt1 swap. Stock manifolds from an f-body will work also if you don't want to buy new ones. You'll love the swap afterwards. The other guys that have done it before me have said it....it's a whole different animal with an Lt1 and the t56 doesn't hurt either.Originally posted by okfoz
Trans Am#5,
John
okfoz
close
- Join DateMar 2001
OHHHHHHHHHHHHHHHHHH THANKS... Iam getting a bonus from work today... WOO HOO...
John
John
Is there more of an issue if you have dual cat's???
okfoz....I just reread my reply above and what I meant to say is stock Lt1 4th gen manifolds will work also if I'm not mistaken. Since I used a Vette Lt1, the stock manifolds wouldn't have worked at all from that motor. Snap a pic of your SFC's if you can.
okfoz
close
- Join DateMar 2001
Were straying off topic, kind of..
I just want to know if my L98 SLP Headers would bolt up to and fit properly with an LT1
thanks
As for the pic, When I change my Torque convertor, I will snap some pix (in a few weeks)
John
thanks
John
Hi, I want to get the Spohn SFCs for my single cat. converter IROC-Z. It has t-tops. Now my main concern is with the cat. converter. Is there going to be a clearance issue? I was under the car looking around and it didn't look like there was any room. I heared the spohns are known for their great fit, but it doesn't look like there is any room. Thanks. -89IRO
okfoz
close
- Join DateMar 2001
I had to move my exhaust a little, no biggie a little heat with a torch and then pry it over...
John
John
Quote:
It's almost a sure thing that you will at least melt the carpet & the wiring that's there. I removed the seat belts, seats, scuff plates & pulled back the carpeting & wiring. I even had a buddy watch for smoke & flames. Just did mine on Saturday. BTW mine were Competition Engineering bolt in, obviously welded in now with cross bars & extra reinforcemnt plates added.Originally posted by BTS88IROC
okfoz
close
- Join DateMar 2001
Definately LIFT the carpet, get some fire extinguishers take EVERY precaution you can imagine...
John
John
yo' u got a pm bud i need some installedOriginally posted by Trans Am#5
I want to install mine i need to move my exhaust. I have edelbrock headers should i heat them up and do it or what??
okfoz
close
- Join DateMar 2001
I think someone wanted pix of my SSM's
Right Side
Right Side
okfoz
close
- Join DateMar 2001
And the left side:
Keep in mind I had to powder coat (paint) them myself...
John
John
hmm it almost looks like ur exhaust is touching about as much interference as i have. Did u just lower the y pipe a lil i think if i did that though it would be 2 low.ur pass side sfc looks like it goes up closer to the floor than mine.
