gauge problems
Old May 5, 2003 | 09:01 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
gauge problems
Hey, i am having some problem with my stock gauges. I took my gauges out to replace the bulbs, and at the same time i was going to see if i could make some custom white gauges. i had to pull the needles off to do that. Anyways i put it all back together and the speedometer quit working. you can hear the unit turning but the needle doesnt move. i took it back apart and tried to push the needle on further, and even tried to loosen it up in case it was to tight, but nothing. What could this be? i found a auction on ebay where i can buy a new set for $50.00. Should i buy them?
Old May 5, 2003 | 10:13 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i put in my white face gauges the other day and broke the needle off the speedo and none of the others work right anymore, and i was wonderin' if i could maybe fix it
Old May 5, 2003 | 10:41 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
i have no idea, im just gonna buy some new ones, put them in and not mess with them anymore. i was gonna get some white gauges, but like i said, to much risk, i cant do without a speedo. i speed enough as it is.
Ghettobird52
Jul 5, 2024 11:18 PM
rocn7roc
Sep 21, 2021 02:16 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
justin57
Aug 20, 2015 07:05 PM
