map lights
Old May 6, 2003 | 08:14 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
map lights
have 88 iroc convert...needs more interior lighting. I currently have the no frills rear view mirror with just the flip up/down switch. I would like to put in a mirror with map lights (non-auto dimming). Can it be done? and how to do it? thanks
Old May 6, 2003 | 10:10 AM
Tonyrodz's Avatar
Transmission: auto
sure it can be done! I think that's one of the easiest mods to do.
There are some mirrors w/3 or either 4 wires in them.
just pull off your plastic pillar piece on the driver side and run the wires directly to the fuse box. If it was mine, I'd wire one to the door switch-so they go on when the doors are open-one to ground and one to a constant hot-so when the car is off you can still turn on the lights on the mirror.
Also if you search hard enough they have mirrors w/the digital compass, outside temp-etc.
Good luck.
Old May 6, 2003 | 11:17 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Thank you. any mirror off any car should work...right? there are some cool ones out there.
Old May 6, 2003 | 03:19 PM
Tonyrodz's Avatar
Transmission: auto
Yep--pretty much. Just make sure you grab the pig tail that goes w/the mirror(harness).
Old May 8, 2003 | 02:19 AM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
I found a nice one in the junkyard off a Neon. I hate Neons, but the mirror looks good and fit right on. Still gotta wire it up. Sorry, don't have any pics.
Old May 8, 2003 | 10:04 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
prices on bone yard mirrors?
Old May 8, 2003 | 09:56 PM
Tonyrodz's Avatar
Transmission: auto
I've found in my searches that it seems like an outside vendor makes rearview mirrors for all the big(American) car makers--so they should all fit!!
Old May 8, 2003 | 10:25 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I did it, and i wired it into my dome light, so it comes on with the doors open, and also has a seperate ground wire that you have to attatch to the roof support so you can turn the lights on with the doors closed.....very simple install....
BTW, mine is out of a 95 Firebird.
Old May 9, 2003 | 09:50 AM
camaro6spd's Avatar
yeash, i had this very same problem in my IROC convert so i went to a junkyard and just pulled one out of a 91 Chevy Lumina, took as much of the orginal wiring as i could (about a foot). IIRC, one wire is ground, the other is always hot and the other wire you can just hook into the underdash lights so when you open the door the maplights come on...OMG, it make such a difference, the onlything left is to work on the lighting for the people in the back. Cost my like $2 to do, i just removed the old mirror with that little screw thing, i did not rip it off the window, and screwed the new one up......
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
andy74
Sep 3, 2015 08:41 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
Omega
Aug 10, 2015 12:46 PM
