dash swap
Old May 23, 2003 | 11:41 PM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
dash swap
hello everyone, I was wondering if you could swap out the dash out of the newer camaro (91-92), for the older kind (82-90). I like the intior of the older cars better. thans for the help!
Old May 24, 2003 | 08:01 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
it might be easier to buy a 91-92 and go backwards...
but it can be done... several people have done it, but I Believe you have to re-wire either the new dash or your car to work with the dash...
Old May 24, 2003 | 01:45 PM
thanks. thats what I was wondering.I wanted to by a 91-92 camaro and put the older style dash in it. I dont like the 91-92 dash its to rounded for me, but they alreddy have the ground effects, and wing(z28), and the speed density tpi! I just like the older dash that looks like im in a cockpit of an airplane.
Old May 25, 2003 | 05:44 PM
would I beable to do that. anyone! thanks.
Old May 25, 2003 | 11:21 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
I'v got a 85 camaro and I want a 91-92 dash.....Hmmmmmmmmm
Old May 25, 2003 | 11:28 PM
I want ot the other way around! but can it be done
Old May 25, 2003 | 11:34 PM
Car: 85 Z
Engine: 383
The body style had not changed so I would not see why it would not work. The only thing is you would have to go to cable speedo like what I have and I would have to goto VSS like you have.
Old May 26, 2003 | 08:30 AM
okfoz's Avatar
it might be pretty striaght forward if you could get a whole car, then transfer whatever you needed... I did that to do my LG4 to TPI setup... really easy, took some time, but it was not hard at all...
Hint: Step 1, take your project car and take everything off of it that will be replaced, Step 2, Start transferring parts one at a time from your doner car to the project car.
John
Old May 26, 2003 | 03:52 PM
so it sounds like it can be done. I would just have to change to a cable speedo. is the dash the only thing that is difreint on that year
Old May 26, 2003 | 03:54 PM
Car: 85 Z
Engine: 383
Yes, That would be it just the dash....
Old May 26, 2003 | 04:37 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Can be done with a few wiring changes and a little drilling / welding.
Old May 26, 2003 | 04:53 PM
cool. thanks for all the help!
Jorlain
Aug 24, 2022 05:11 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Vintageracer
Aug 11, 2015 08:13 PM
