front GFX repair
Old May 25, 2003 | 07:46 PM
icarus402001's Avatar
front GFX repair
I caught my front end on a driveway. Looks like I'll be curb parking from here on out. Has anyone repaired their front GFX with a triangle missing from a corner and how has it lasted?
Old May 25, 2003 | 08:03 PM
dsaint1347's Avatar
I'm in the process of doing that now, I brought a 91-92 style GFX and it has a slight crack on the corner which I am going to fiberglass tomorrow. I think it's the proper way to fix it.
Old May 25, 2003 | 08:35 PM
dsaint1347's Avatar
Try this site I found doing a search.
Here
courtesy from MikeInAZ
Old May 26, 2003 | 12:31 AM
Mathius's Avatar
Don't use fiberglass guys, I can tell you from personal experience it will just crack. Either use epoxy to fill the crack, or look into getting a plastic welder. There's also a few places that sell this sort of equipment for repairs like.....
http://www.urethanesupply.com/
and
http://www.fusor.com/products/pr_overview.asp
Good Luck, I'm in the process of going with an epoxy repair. I cut a "v" into the crack, and filled it with epoxy. I've yet to sand, so I don't know how it's going to turn out, but my fiberglass repair was a waste of time. Fiberglass is WAY too brittle. It cracked right away.
Mathius
Old May 26, 2003 | 12:32 AM
Mathius's Avatar
That 3M Structural Adhesive in the link is a great idea as well.
Mathius
Old May 26, 2003 | 07:45 AM
dsaint1347's Avatar
Good looking out!
What brand of epoxy did you use that's over the counter?
Old May 26, 2003 | 10:07 AM
Mathius's Avatar
I used Loctite "Putty" epoxy. It kneads up real soft and workable, something I've had experience with in a hobby of mine. Like I said, I haven't sanded it down yet to see what kind of finish I'll get, but it should be like any other body filler, just a matter of getting the filler sanded smooth. I'm more concerned about how well I notched my "V". I can always leave some overhang in the rear of the spoiler where you won't see it under the car, to give it a bit more strength as well.
The stuff dries hard, but it's also flexable, so it won't likely crack like fiberglass. Again, I can't stress enough to not use fiberglass. I can show you before and after pictures. Fiberglass filled over my crack so well, you couldn't see it and I knew where to look! But just the slightest bump caused it to crack, and then I was able to just peel my whole repair off in one piece.
Mathius
Old May 26, 2003 | 10:10 AM
Mathius's Avatar
Here's a thread on my fiberglass repair. Avoid fiberglass:
https://www.thirdgen.org/techbb2/sho...ght=fiberglass
Mathius
Old May 26, 2003 | 10:35 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I can tell you from personal experience fiberglass repair will not hold up. If you just recently bought a whole GFX kit I would just buy that one front piece. They are not that expensive.
Old May 26, 2003 | 11:35 AM
dsaint1347's Avatar
This is the best!
Mathius
Thanks that thread helped out alot, I hope it also helped out icarus402001. Oh and sorry for the misinformation the first time, You live and you learn.
Old May 26, 2003 | 03:54 PM
thanks, dsaint. I don't have the cash for a new part or body shop right now. These tips will help a lot
Old May 28, 2003 | 09:39 AM
Zeke3Elevn's Avatar
Re: front GFX repair
My body shop guy did a good job with mine ... it had a huge crack on the pass side and you can't even tell its cracked... even looking at it up close you can't tell ... if you look behind it, theres some brown stuff he used to seal it ... im not sure what it is... email me if you want to know and il lcall
Matt
Old May 28, 2003 | 09:08 PM
dsaint1347's Avatar
Let all of us know if you don't mind.
Old May 29, 2003 | 09:10 AM
Zeke3Elevn's Avatar
Its called duramix
Old May 29, 2003 | 06:30 PM
Thanks, Zeke
Old May 29, 2003 | 06:34 PM
dsaint1347's Avatar
Thanks, Zeke
Old May 29, 2003 | 10:22 PM
Dan88IrocZ's Avatar
My front bumper split where the blinkers are, the crack was about 1/4 inch...my shop used a plastic welder and it looks brand new, and it's held up for over a year now.
Old May 30, 2003 | 08:10 AM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
Thanks Zeke
Old May 31, 2003 | 05:31 AM
louie's Avatar
Car: 91 Firebird
I used some stuff by 3m, starting to look good.
Old May 31, 2003 | 05:43 AM
louie's Avatar
Car: 91 Firebird
I think its starting to look prity good, just a little more work and then some pant.
Old May 31, 2003 | 05:47 AM
louie's Avatar
Car: 91 Firebird
3M Structural Adhesive, about $30.00
Old Jun 1, 2003 | 04:23 PM
Any of these things work for an actual triangle of material missing? Nobody seems to have much more than cracks.
Old Jun 2, 2003 | 12:48 AM
Mathius's Avatar
I'd get a plastic welder, I think they're $30 at harbor freight when they put them on sale, which is often, but that's just me.
Mathius
Old Jun 2, 2003 | 04:30 PM
louie's Avatar
Car: 91 Firebird
re:Any of these things work for an actual triangle of material missing? Nobody seems to have much more than cracks.
if you look at the first 2 pic you can see the big chunk missing, just use some screan or some card bord, this stuff will bound any thing.
Old Jun 2, 2003 | 04:36 PM
louie's Avatar
Car: 91 Firebird
heres a better look at the in side of the front clip, you can see the card bord we used to form the missing peice of the clip.
Old Jun 2, 2003 | 04:54 PM
patrickm00's Avatar
or just go to a junkyard, and cut a chunk of urethane of a ripped up bumper and use that as most of the filler. then you basically have a bunch of cracks (depending on how you cut the pieces and how many curves you have)
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
May 20, 2016 07:01 PM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
LittleFranks
Aug 20, 2015 03:55 PM
