91-92 guage cluster....
Old May 25, 2003 | 10:36 PM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
90-92 guage cluster....
Would a 91-92 guage cluster fit in my stock 85z?...If soo what wires would be diffrent? Anybody try this if soo please help me out I would like to do this I like the style of them.
Thanks!
P.S. I'm not using a computer at all so don't need to worry about that!
Old May 26, 2003 | 12:25 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: 90-92 guage cluster....
It certainly would, as long as the rest of the dash goes with it. You can get the cluster to work but, it's hardly worth the trouble from what I've seen. Do a search in the Electronics forum for this. I forget the name but a member has swapped in just the cluster.
Regardless, the speedometer in the above mentioned cluster is electric, not cable driven such as your current. You would have to put a VSS unit in place of the current speedo cable on the transmission and, swipe a VSS buffer box along with the wiring to it from a 'bird.
Old May 26, 2003 | 04:03 PM
Car: 85 Z
Engine: 383
Well I found out that it can be done so all I need now is to find out how to hook up my VSS.....It is from a 91 firebird dose anybody know? It dose not need to goto the ECM being I don't have one....Thanks!
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
