GM Discontinued it, now what????
Old Jun 7, 2003 | 03:28 PM
jeff's Avatar
GM discontinued the vent in the following picture. Where can I buy a new set of these? As you can see the paint is peeling off of mine.
Old Jun 7, 2003 | 03:35 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Try junkyards, or just repaint it.
Old Jun 7, 2003 | 03:39 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
What year is your car? I think mine aren't painted.
Old Jun 7, 2003 | 05:02 PM
jeff's Avatar
1992 Firebird. What would I paint them with. How would I find an exact match for the color?
Old Jun 7, 2003 | 10:25 PM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
You may be able to find it at www.yearone.com
Old Jun 8, 2003 | 11:43 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If all else fails, just paint them black. Should look good since the dash is black and grey.
Old Jun 8, 2003 | 01:33 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
I'm pretty sure Krylon has a line of paint now that is supposed to stick to plastic better than regular enamel spray paint. You might be able to find a close color, but your best bet is probably to just paint it black.
Later,
Harry
Old Jun 8, 2003 | 02:11 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Later,
Harry
Trouble is, I cannot find that "Fusion" paint anywhere in CA.
I'll be traveling to the Seattle area next week. Anyone know if there's a place there that carries this stuff?
Old Jun 8, 2003 | 02:37 PM
Dean92RS's Avatar
Car: surprise!! a '92RS!!!
Transmission: 5 speed "M39"
Krylon "Fusion" plastic paint
"The 12-ounce aerosol can of Krylon Fusion is available in 16 colors and can be purchased several places including some home improvement stores, Wal-Mart, Ace Hardware, True Value Hardware, Sears Hardware and Sherwin-Williams. Some stores are limited on colors, while others can order shades from Hunter Green to Sun-Dried Tomato. Prices range from about $3.97 to $5.99. "
I found the above by googling "Krylon Fusion".
Hope this helps. BTW, I had no idea this stuff existed. Great to learn something every day!!! Thanks!!!
Dean
Old Jun 9, 2003 | 08:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
everybody and their brother sells vinal paint in a gray color that matches most GM gray interiors.
Old Jun 9, 2003 | 12:31 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Krylon Duplicolor should work. I just bought a can of black Krylon Fusion paint which is the new kind that bonds to the plastic. I will post my findings as soon as I know how well it works.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
xxblade31
Sep 21, 2015 01:36 PM
F-body-fan
Sep 17, 2015 12:16 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
irocnroll89
Jan 9, 2001 11:23 AM
