Tire Rotation
Old Jun 17, 2003 | 09:04 PM
92Camaro5.0's Avatar
Car: 92 Camaro
Engine: 305 TBI
Transmission: 5 speed manual
Tire Rotation
Ok, I just found out that my front wheels are different from my rear ones. This poses a problem when I try to rotate the tires. What should I do?
Old Jun 17, 2003 | 09:18 PM
MadZ28's Avatar
Car: 91 Z28
The rear wheels were made deeper to fit the brakes in the back. Otherwise there is really nothing you can do. I am in the same boat
Old Jun 18, 2003 | 03:26 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If your tires have free rotation, take the car up to the shop that installed them and tell them to rotate the tires and let them know that they have to dismount them first since the front and rear wheels are different offset.
Old Jun 18, 2003 | 07:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
As stated. the tires have to be dismounted and rebalanced. And I don't think your free rotation is going to cover it. One of the many advantages of owning a 3rd Gen car.
Old Jun 18, 2003 | 08:54 AM
82camaro's Avatar
Car: 82 camaro SC
Most shops will give you the free rotation, but charge for the dismount/mount and rebalance. FYI, the FRONT wheels stick out further than the rear--to clear suspension stuff. The brakes aren't a problem. The fronts will work on the front and the rear of the car, while the rear's only fit the rear. If you can get a couple more front wheels(so you had a set of 4 front wheels on the car), you could do rotations and everything would be fine.
Old Jun 18, 2003 | 10:04 AM
nolanr0413's Avatar
Car: Trans am
i cant even change mine from left to right cause i have directional tires. I think it will cost about 50 bucks to have the tires moved around.
Old Jun 18, 2003 | 11:20 AM
DJP87Z28's Avatar
Again, one of the advantages of owning a 3rd gen car. also you never rotate tires left to right anymore, always front to rear on the same side.
Old Jun 18, 2003 | 01:27 PM
82camaro's Avatar
Car: 82 camaro SC
If the directional tires aren't asymmetric, you can rotate side to side if you dismount and remount the tires putting the inside sidewall out. However, if they are asymmetric(like my eagle GS-C's) they cannot be put on the other side of the car. My GS-C's have a separate left and right tire
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
mfp189
Sep 27, 2015 09:25 AM
