Auto body help...
Old Jun 24, 2003 | 05:01 AM
Chris's 85z's Avatar
Car: 85 Z
Engine: 383
Auto body help...
I am getting ready to repaint my car and I am sanding down and feathering back all the chips in my paint. Most of it is going to the metal and I am using a self etching primer only were there is metal showing...... Well when I put a coat of the primer on I can see a line were I have featherd back the paint. I am using 80 grit to feather back and then using 220 grit to smooth it out. Now is it normal to beable to see the out line of the feathering with the primer or am I doing something wrong? Any help would be GREAT!
Old Jun 25, 2003 | 08:40 PM
91bluemetalicRS's Avatar
can you take a picture of what you are describing. How much of the car are you repainting? The whole thing or just a section of it. When you put your primer on there should not be any lines. body should be smooth, If you have definate lines now you will still have lines after base and clear goes on.
Old Jun 26, 2003 | 04:14 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
are you using rattle can primer. if so, it is not buildable. meaning that the layers that you put on will not build up. i used PPG K36 primer surfacer on my whole car, even the bare metal spots. this primer requires a gun, reducer and catalyst(hardner). when you put several coats of this stuff on, it will build up. then you sand it down until it is smooth. you must make sure that you fanned the chips out enough anyway. hope this helps alittle.
Old Jun 26, 2003 | 05:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
A good featheredge will show no lines. It should blend very smoothly. But like heavy_chevy said, you need to use a high-build primer. Its a primer to use to fill in sand scratches and stuff. When its all primered, you spray a guide coat and block sand to look for low spots.
Old Jun 26, 2003 | 06:04 PM
Car: 85 Z
Engine: 383
Thanks for the help guy's!......I also just talked to a guy and he said I would need to use a 2k primer. I have the chips featherd about 6"should do it. My new Finishline HVLP Gravity Feed gun just showed up I'm going to be painting it next week I can't wait!
:lala:
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
ezobens
Aug 19, 2015 10:29 PM
Exxon Limited
Aug 9, 2015 08:13 PM
